Previous in Forum: Improving the Performance of Stove Hood Exhaust   Next in Forum: Just One of Those Schrodinger Alien AI-type Thoughts
Blackview's BV 8000 Back Cover Removal: How-to?
07/19/2018 9:03 PM
HI!
does anyone know how to remove the back cover from a Blackview BV8000?
I removed all the screws from the back cover, as well as both side clamps. The front lid with the screen got immediately loose, but the back cover does not. I have the feeling the (rubber / silicone) gasket may have got tacky and prevents removing the lid from the frame.
in the picture, the upper part is Front.
I tried to slide a thin blade between the frame and the cover.... but it did not work, so far I have the feeling that I am getting close to a no return point (ie: dent in the cover or so)
Thanks!
PS: 1.- I searched the web and did not find this info for the BV 8000. Previous and posterior models (on youtube) are quite different.
2.- The USB "C" connector on the phone does not work (hence, battery does not load---- phone is dead--) want to check if a foreign body may be mechanically interfering / look for malfunctioning connections, etc
Re: Blackview´s BV 8000 back cover removal: how-to????
07/19/2018 9:08 PM
Try YouTube. They know everything.
https://www.youtube.com/watch?v=9yLEemeXFnY
07/20/2018 5:16 AM
Thanks, but as I said in my OP, this model is different to its predecessors and later versions.
07/19/2018 9:43 PM
You probably need to heat it up....try a hair dryer....
http://bbs.blackview.hk/viewtopic.php?t=176594&start=70
07/20/2018 5:17 AM
had been there....
07/20/2018 3:40 AM
According to this, one can contact either Nancy or Kelly with it using Skype; these would be the people to ask and the method to ask it.
<unsubscribes>
6
07/20/2018 5:28 AM
I was actually looking for someone with first hand experience who may have had this problem before. Thank you anyway. I have already done the search you did.
Also thanks for publicly showing your interest in this topic by -unsubscribing- cause this kind of arrogance made CR4 loose a lot of followers. Ten years ago 400 people would have been online right now.... at this very right moment there are 86 !... in a couple of years from now there will be only one: you! Enjoy your tea!
Re: Blackview´s BV 8000 Back Cover Removal: How-To????
07/21/2018 6:18 AM
I trust that you know it is not the cable.
Register to Reply 7 comments
lyn (1); Oomborrie (1); PWSlack (1); r&ddoc (3); SolarEagle (1)
