Previous in Forum: Read DC Meter Coil Readings in 4-20 mA   Next in Forum: What Calculations are Possible with Below Specs when Selecting a MV Softstarter
11 comments
Chemical Engineering Costing
07/21/2018 12:36 PM
Does anyone have the Plant Cost Index for 2018??? I searched online and it's not accessible anywhere w/o a subscription... I have to estimate a cost for a shell and tube heat exchanger and need those indices for 2018, any help would be appreciated!
Re: Chemical Engineering Costing
07/21/2018 12:42 PM
Just add a disclaimer.....Prices subject to change due to market conditions, tariffs, trade wars etc....
https://link.springer.com/content/pdf/bbm%3A978-94-011-6544-0%2F1.pdf
07/21/2018 1:00 PM
Are you kidding? 166 pages?
Aren't there any CliffsNotes???
@Krissssy,
And what, exactly is your job, or is this your college/school project? Have you contacted any boiler makers for rough quotes? It sounds like that's all you need.
Or, are you just trying to get the forum to do your homework for you?
Help Designing Shell and Tube HX
07/21/2018 1:04 PM
Firstly, I am a college student and I'm asking if anyone has the resource available... I did not ask for anything else but the cost indices for 2018 to complete my cost estimate. It's not available online, that's why I asked... no need to be like that :(
07/21/2018 1:51 PM
Did you contact any boiler manufacturers for a quote?
Fire tube boiler, Fire tube boiler price,Shell Tube Boiler,Fire tube ... - ZBG
Steam Boilers - Shell and Tube Steam Boilers Manufacturer from ...
www.anudeepboilers.net/steam-boilers.html
Ask for Price.
Shell and Tube Heat Exchangers & Unfired Boilers | Boilersupplies
https://www.boilersupplies.com/graham-heat-exchangers
Shell and Tube Heat Exchangers & Unfired Boilers | Boilersupplies Graham ... Using off-the-shelf pope reduces manufacturing costs and lead time to ...
07/23/2018 12:25 PM
Maybe, you could find the cost of a similar older shell-and-tube exchanger, and then estimate the costs to present-day amounts, by applying CPI values in a spreadsheet, to get total(s) good enough for estimate(s) for schoolwork, today...
07/26/2018 11:16 AM
I did this and it was sufficient, thanks to all for the suggestions.
07/27/2018 12:54 AM
Thanks for the feedback.
07/25/2018 11:46 AM
Have you looked into a recent issue of ''Chemical Engineering'' magazine at it's inside back cover yet?...
07/21/2018 2:17 PM
Just skip to page 286....
Good Answers: 445
07/22/2018 10:46 AM
That is copyrighted material, sharing it is a violation of the terms of use of this site. If you do not need that exact publication, you may find some of these sources useful.
07/22/2018 11:17 PM
Once you have calculated or know the input and output requirements of both the material to be heated/cooled as well as the heat transfer medium temperatures and pressures, contact a couple of manufacturers for quotes. (Don't mention that you are a student)
Register to Reply 11 comments
Casper71 (2); Krissssy (2); lyn (2); MR. Guest (2); RAMConsult (1); SolarEagle (2)
