Previous in Forum: Turbine Driven BFP: Better Than Motor Driven?   Next in Forum: Female Luer Stainless Steel Hub Hypodermic Needle?
Cr2O3 Coating on a Thin Sleeve?
09/20/2007 3:02 AM
I don't know how to do that coating Cr2O3 on the sleeve. Because the sleeve is very thin it is easy to distorted after machinging. The sleeve ID.410mm,OD.430mm,and the material is SS316. Please help me. Many thanks!
Re: how to coat on the thin sleeve?
09/20/2007 4:58 AM
Is there any way of doing it using the precipitation of particles using flame-spraying, in the same way as worn bearing journals can be built up?
Good Answers: 143
09/20/2007 11:50 AM
Ditto on the flamespraying. That's sort of a standard way, though I don't know about thermal stresses if the section is really thin. Be careful; Cr2O3 is nasty stuff.
Re: Cr2O3 Coating on a Thin Sleeve?
09/21/2007 8:02 AM
If the material is 316 you may want to try Kolsterising www.kolsterising.info
Surface hardness of 68-70 HRc at depths of 20-50 microns without loss of corroison resistance and without dimensional change.
11/10/2007 3:32 AM
I'think do the coatiing it's no problem by Plasma spraying.
you do the base material ID is much to spraying. But you must do the coating
with the air cooling. That's good maybe.
Anonymous Poster (1); BillM (1); PWSlack (1); TVP45 (1)
You might be interested in: Coating Services
