I need to vibration isolate a TE cooling assembly (TE unit + Fans) that is mounted to an instrument. We ran some experiments and determined that a frequency of approximately 100 Hz is what is showing up as noise in our system.
I've tried using Sorbatane, and many other type of foam/rubber. At this point the best candidate is the low density egg crate looking packing foam that I recieved with a shipment (so i don't even know what it is).
The next big hurdle, once I determine what to use, is figuring out how to mount the assembly. Plastic screws are transmitting the vibration.
At this point having the TE Cooler sitting on top of the packing foam and being held down with Zip-Ties wrapped around the unit have performed the best.......BUT....I cannot release this to production.
I'm going to start doing web searches and making calls, but hope to gain additional insight from the guru's here.
there will be bonus points for ceativity
thanks
