Previous in Forum: Electric Furnace - Casting Equipment (Used)   Next in Forum: how to create artificial stone
furance material loading tray braking problem solution
09/22/2007 5:12 AM
i am in search of the furnace material loading trays of alumina 48% sio2 45% app.
and also the material which is used to join them please suggest the solution the temp of furnace is 1200 degree centigrade ,currently we are facing the tray braking problem ,the finding so far is that due to the penetration of the material in the tray makes the trays weaken and breaks tray suggest solution.
Amol
Re: furance material loading tray braking problem solution
09/23/2007 7:41 AM
We can supply Super Refractory Assam Sillimanite ~63%Al2O3 @Rs 20,000/-per ton x 15 Ton per Truck.
Please let us have more query,
BR
MM
09/23/2007 10:43 PM
Please let me know the email adress to contact you or if possible please send me the sample for the trial , the detail of the material supplied by you.and how the problem will get solved by your product.
milind.narkhede@cgl.co.in,mgnbld@joinme.com,
Amol
Register to Reply 2 comments
You might be interested in: Cable Trays, Deaerators
