Previous in Forum: Seal   Next in Forum: Square Ball Transforms U-Joint
8 comments
Repair of Tubesheet for TEMA R Tube Sheet
08/06/2018 12:19 PM
Dear All,
TEMA does not specify the criteria and is silent on repair procedure if the drilled holes in new tube sheet exceed the limits specified in TEMA RCB 7.21
Please suggest that in case the drilled holes are more than the limits specified in TEMA what would be the remedy if the drilled holes exceeding the maximum limits specified in TEMA and exceeds 10% of the tube count and on the other hand if the drilled holes are more than the limits specified in TEMA what would be the remedy if the drilled holes exceeding the maximum limits specified in TEMA and is less than 10% of the tube count.
As per my own understanding, ASSME VIII is also silent for specifying the criteria of acceptance or rejection of newly drilled tube sheet if the drilled hole dia are exceeding the TEMA limits.
Could someone share the experience what normally exchanger manufacturer do in this case or what are the general practice adopted by Tubesheet drilling companies.
This is a common issue and there are normally results in long debates between Purchaser and Manufacturer and finally, it is a compromise due to cost and time involved.
Also, NBIC is silent on the acceptance and rejection criteria as well whereas on repair procedure (NBIC part III covers some methodology for tube sheet(S 1.2.11.6 )however, it is somewhat more generalized and do not cover how tubesheet bulging would be avoided.
also, the cost of new tube sheet is a major factor. Such acceptance/rejection criteria is even not available in API standards.
Normally, in such cases third-party inspectors recommend to plug the tube sheet holes, provided the thermal performance is acceptable to purchaser.
Could any suggest any solution or info which could lead to simplicity and suggest a repair procedure acceptable in light of code and standard with reference?
Best regards
Ahmed Attyub
Re: Repair of Tubesheet for TEMA R Tube Sheet
08/06/2018 5:16 PM
This sounds like an issue to be worked out between the purchaser and the manufacturer, and the design engineer...If your supplier can't meet specs, it's time to shop around...
http://www.heatexchange.org/pdf/techsheets/TechSheet106.pdf
http://www.tema.org/inquiries/
08/06/2018 7:20 PM
08/06/2018 7:52 PM
Where is all this taking place--Elbonia??
08/06/2018 8:54 PM
Are tubes welded or rolled to tube sheet?
08/10/2018 12:55 PM
Dear Sir,
It is Strength Welded
Good Answers: 445
08/07/2018 12:05 AM
It sounds like you are trying circumvent the clearly stated limit on the number of oversized holes. I hope that you're not looking for "repair procedures", such as bushings or resizing the hole by welding filler material in and redrilling to the correct size, to compensate for the poor fit between some of the tubes and the tubesheet. Such methods are unsafe and generally not allowed. Basically it's "too many oversized holes, no good. Too many undersized (but still within spec) holes, no problem"
There is a simple solution, insist on seeing the QA results of other customers' purchases, and find a different vendor if you don't like the results.
08/10/2018 1:10 PM
I would like to mention that this happen while drilling by a local heat exchanger manufacturer while manufacturing new heat exchanger.
It is established fact that the 15 % holes are over drilled beyond the limits defined in TEMA.
We insisted on providing new tube sheet but the manufacturer donot agree as there is no acceptance and rejection criteria defined either in ASME VIII or TEMA . The are insisting on extended warrantee and possible repair.
We do not find any repair methodolgy permitted by the code for filling the complete hole by welding and re-drilling and methodology to avoid tube bulging due to heat input
Additionally, purchasing a new tube sheet and re drilling is a 3-4 month activity
and we are still stuck up for the solution
Good Answers: 445
08/12/2018 5:43 PM
You're right, it is usually disallowed by most codes because it dangerous, therefore you will not find any legal fix. The reason for this is already known to you, since as you said "...to avoid tube bulging due to heat input..."
Some of the problems in addition to your own observation, are: metallurgical changes in the tube sheet which lead to stress cracking, non-uniform bedding material for the seal-welding (welding on welding instead of welding on base-metal), lack of proper welding post heat treatment, the possibility of out-of-round "repaired" holes which in turn leads to non-uniform contact between tube and sheet, etc., etc.
Your QA "team" should be looking into why you have so many off-spec holes, and how to prevent that and other defects in the future, instead of trying to find illegal and dangerous methods of supposedly repairing the aftermath of your poor manufacturing procedures.
Register to Reply 8 comments
Anonymous Poster (1); Attyub194 (2); RAMConsult (2); SolarEagle (2); Tornado (1)
