Previous in Forum: Electrical Installation in Hazardous Area   Next in Forum: Electrical Question
NGR Connection Through ATS
08/08/2018 12:25 PM
In our project, we have both utility Transformer and generator power source. We are using 3-Pole ATS (automatic Transfer Switch). The grounding system is HRG (High Resistance Grounding). I would like to transfer the NGR to the neutral of utility transformer and Generator with the transferring the power source. Could please suggest how can I do it.
I am using a reversing contactor for the switching and operating it through an auxiliary contact of the ATS. I am not sure, I am doing the right thing.
Thanks,
- Lasam
Good Answers: 140
Re: NGR Connection Through ATS
08/08/2018 1:56 PM
The first thing you need to do is contact an electrical engineer who knows the codes and standards where your project is located.
If this was in Canada, I would tell you that.... with a 3 pole transfer switch, the neutral from the transformer and the neutral from the generator must be connected to a hard bolted neutral bar in the transfer switch and that any neutral to case ground at the generator needs to be removed.
As to where the HGR resistor gets connected depends upon where your utility service point is located.
If the secondary of your transformer is your service box, then the HGR resistor must be connected between the neutral of the transformer and the system grounding grid with nothing between them. As well, a connection between the neutral from the transformer must be bonded to your equipment bonding system.
If the transformer is not your service point from the utility system, the HGR needs to be connected to the utility service point neutral and the bonding system needs to be established. These two separately derived systems need to be interconnected from a grounding perspective.
Call a pro...
08/08/2018 2:55 PM
A professional will cost money. CR4 doesn't charge anybody for services rendered.
Good Answers: 445
08/08/2018 4:40 PM
Interesting, your local utility allows customers to tamper with the utility mandated earthing methods, and utilizes High Resistance Grounding on its distribution transformers? Both are highly unlikely in systems where codes are followed.
It is much easier, safer, and cheaper to simply install a dedicated NGR in the generator neutral. Problem solved, and your AHJ (like North of 60), will be much happier.
Get a copy of the latest revision of IEEE Std C62.92.4-2014 for more info.
Good Answers: 22
08/09/2018 9:38 AM
There is no problem technically having two earth connections on all the time (assuming you parallel the local generation with utility), as it is HRG at both locations.
Why complicate with transfer scheme for HRG!
Raghunath
Good Answers: 445
08/09/2018 10:55 AM
"...assuming you parallel..." The OP is using an ATS, such switches are either/or and are not allowed to connect to both sources at the same time. Paralleling two sources requires a synchronizing panel, two independent electrically operated breakers, and an entirely different protective relaying scheme.
North of 60 (1); raghun (1); RAMConsult (2); redfred (1)
