Previous in Forum: The Development History of Integrated Circuit   Next in Forum: EsDesigns' New EV Driveline
Electrolytic Capacitor Damage Characteristics
08/17/2018 1:20 AM
Electrolytic capacitors are used in large quantities in electrical equipment and have a high failure rate. Electrolytic capacitor damage has the following performances:
1. The loss of capacity or capacity becomes smaller;
2. Slight or severe leakage;
3. The loss of capacity or capacity and leakage.
The methods for finding damaged electrolytic capacitors are:
(1) Look: Some capacitors will leak when they are damaged. There will be a layer of oil on the surface of the circuit board under the capacitor or even the surface of the capacitor. This capacitor can never be used again. Some capacitors will bulge after being damaged. Continue to use; therefore, in the early selection of capacitors, it should be good quality, try to choose a well-known brand of capacitors, such as the capacitor giant - Guoju capacitor.
(2) Touch: Some electrolytic capacitors with serious leakage will heat up after starting up, and even hot when touched with fingers, this capacitor is replaced;
(3) There is electrolyte inside the electrolytic capacitor. If it is baked for a long time, the electrolyte will dry out, resulting in a decrease in capacitance. It is important to check the heat sink and the capacitance near the high-power components. The closer to it, the more damage.
Re: Electrolytic capacitor damage characteristics
08/17/2018 5:19 AM
Components are tested based on the datasheet.
You just listed a few parameters, there is way more than that.
Building the future!
08/17/2018 9:04 AM
No. Electrolytic capacitors do not have a high failure rate. They have a known and understood failure rate based on mostly environmental attributes. Mechanical systems, particularly lubricating oils, have a higher failure rate than electrolytic capacitors when properly designed. (When was the last time you changed the oil in your vehicle? Did you change any electronics, too.)
Oh, speaking of failures. You made a nice attempt at posting spam on CR4 by also providing what you thought was useful information. Unfortunately for you, that information is wrong and I now doubt the quality of any product you promote.
08/17/2018 3:05 PM
I'm surprised the admins haven't removed Marria's account given the stealth spam posted yesterday. This makes two spam postings with dubious information to divert attention from the spam links.
Re: Electrolytic Capacitor Damage Characteristics
08/17/2018 3:35 PM
Maybe slapping a tariff on Guoju products will help to fix things. Or maybe not.
08/17/2018 5:05 PM
Go-who?
08/17/2018 6:36 PM
Please see OP link.
08/19/2018 3:58 PM
Spam it may be but it raises a point regarding point (1) Look and (3) dry electrolyte.
Now looking for an electrolytic problem is great but it almost lost me an eye once.
Did you know that the outer metal cases of small electrolytics which have their electrolyte dried out turn into fantastic rockets when powered up? I Didn't. Now I always wear safety glasses.
Register to Reply 7 comments
Brave Sir Robin (2); Ivanov327950 (1); jack of all trades (1); redfred (1); Tornado (2)
