Calculating Excitation Voltage and Current from a Synchronous Generator?
09/26/2007 5:07 AM
Can any one explain me how can i calculate excitation voltage and current of 660MW generator having Xd=225.5% ,Xd"=21.4(sat), with terminal voltage of 22KV and power factor is .85.No other information is available????????????
You must have the saturation curve(V x Iexc) of the equipment as well as all the parameters concerning the primary side of the transformer, such as primary resistance and all the primary impedances.
Excitation voltage is a design parameter and to be given by manufacturer.The parameters ref are for different purpose like to calculate Fault current etc.
Re: Calculating Excitation Voltage and Current from a Synchronous Generator?
09/27/2007 12:28 AM
Contact the Manufacturer.
If you dont know the manufacturer return to line one of this comment
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
