Previous in Forum: How Can Over-pressure of a Gas Main Cause a Fire/Explosion in a House?   Next in Forum: Siberian Politician Says We'll Have Cloned Mammoths by 2028
14 comments
The Engineer
Good Answers: 129
RemoveDEBRIS Satellite Captures Space Junk
09/20/2018 8:51 AM
I came across this article and thought it was pretty cool. For years scientists have warned about a "space junk" problem. Basically old satellites and spent boosters are still in orbit and pose a risk to other satellites, particularly if they collide with another satellite and create debris. Recently the RemoveDEBRIS Satellite was launched from the ISS as a sort of proof of concept. Here's the article:
...Development of the RemoveDEBRIS satellite was funded by the European Commision and ten international partners. It was transported to the International Space Station (ISS) aboard the SpaceX CRS-14 mission. The satellite was then deployed from the ISS on June 20, 2018, via Nanorack’s Kaber Microsatellite deployer. Testing of the experimental space junk net was conducted on September 16 with the satellite successfully capturing a target cubesat travelling at 27,000 kph (17,000 mph).
“We are absolutely delighted with the outcome of the net technology.” said Professor Guglielmo Aglietti, Director of the Surrey Space Centre. “While it might sound like a simple idea, the complexity of using a net in space to capture a piece of debris took many years of planning, engineering, and coordination between the Surrey Space Centre, Airbus and our partners – but there is more work to be done. These are very exciting times for us all.”
In addition to the net, the RemoveDEBRIS satellite carries a second novel solution to the problem of space debris. In the coming months, SSTL ground control will attempt to capture a second target cubesat using a harpoon.
The United States Space Surveillance Network is currently tracking 40,000 objects orbiting Earth. It’s estimated that this accounts for 7,600 tonnes of ‘space junk’ orbiting the Earth at speeds of around 48,000 kph (30,000 mph). This debris poses a significant concern to the industry as multimillion-dollar satellites are becoming increasingly vulnerable to potentially crippling strikes. Finding practical solutions to clear the debris is, as a result, important to ensure the safety of both current and future missions.
The article can be found here
Re: RemoveDEBRIS Satellite Captures Space Junk
09/20/2018 10:22 AM
Is it going to be called the "Space Janitor Project"?
09/20/2018 10:54 AM
I wonder what space junk goes for, per lb...Will we see it for sale on Ebay someday? Will the Chinese sell copies? This one I know...yes, yes they will....
09/20/2018 11:21 AM
First: Categorize all Chinese satellites as junk.
Second: Take them out and throw them in the trash.
Job done.
09/20/2018 11:38 AM
Most of the debris is due to two events: the collision of the Russian Kosmos 2251 and Iridium 33 satellites 10 February 2009 and the intentional destruction of the Chinese Fengyun-1C weather satellite by a Chinese missile on 11 January 2007. Unfortunately, both debris fields are in polar orbit and intersect the orbits of equatorial satellites at about 90 degrees.
https://www.reddit.com/r/askscience/comments/48gkvg/is_most_space_debris_traveling_the_same_direction/
Satellite collision:
Point of collision
Debris fields after 20 minutes
Debris fields after 50 minutes
https://en.wikipedia.org/wiki/2009_satellite_collision
Known orbit planes of Fengyun-1C debris one month after its disintegration by the Chinese ASAT (orbits exaggerated for visibility)
https://en.wikipedia.org/wiki/2007_Chinese_anti-satellite_missile_test
Here is a condensed history of our collection of orbital debris:
https://gizmodo.com/a-history-of-garbage-in-space-1572783046
09/24/2018 12:06 PM
Good Answer. ''GA'' from me.
I don't suppose it was economically and physically feasible to launch another rocket in time to catch up to either one of the other two satellites in question, attach itself to one of them, and either, re-directing that combination away from Earth, or both into a decaying orbit that will cause the two conjoined satellites to both burn up in the atmoshere?...
09/24/2018 9:23 PM
The satellites were not conjoined, they approached at about 90 degrees at a differential velocity of about 25000 mph. Both continued on their previous courses, only each one in thousands of pieces with diverging trajectories.
Each of these pieces ends up in its own orbit. Each tiny piece still packs a huge amount of energy if it hits another satellite or spacecraft, and when this happens, you have many more pieces. Atmospheric drag eventually removes some debris, but at high altitudes it takes many years. If the number of fragments increases from collisions faster than atmospheric reentry can clear them out, then eventually space will become unnavigable.
We may be living in the unique period of history where we have access to space and the benefits that derive therefrom: satellite communications, navigation (GPS), weather satellites, etc.
09/24/2018 10:07 PM
I suspect that until this collision, it was thought highly unlikely that satellites could collide, given the huge amount of volume up there.
Moving the Iridium satellite, assuming it still had propellant left, would have been a much more feasible way to prevent the collision than launching another satellite to dock and then move the satellite, even if the collision could have been predicted far enough in advance to plan the mission.
09/20/2018 3:31 PM
Does anyone know what this test satellite will do with the collected debris/junk? Will the satellite return to the ISS or just simply decelerate, re-enter and burn up into microscopic sized debris in our atmosphere?
09/20/2018 4:29 PM
09/21/2018 9:51 AM
Just an observation:
A. When a rocket or a satellite is launched into space, is there a plan in place ( part of the launch plan ) to pick up the trash produced ?
B. Why do scientists wait until an issue is serious, before anything is done to pickup the debris ?
I think I can answer my own questions:
Many times I go on a roof or underneath a house to repair or install a piece of equipment and I see trash everywhere ( nuts, screws, washers, bits of paper, metal, wire, plastic etc ) .
When I asked another technician about this refuse, the most common answers I received were:
1. It's not mine.
2. I don't have time to pick it up.
3. Nobody is going to see it anyway.
4. We are not getting paid to pick up trash.
5. Somebody else will clean it up.
It seems that clean up is always relegated to some kind of special event, sort of like a feel good project. Adults actively train children to propagate this mentality. The adult will take the child to an event then will flick a gum wrapper or cigarette butt onto the ground.
09/21/2018 11:27 AM
Actually, most of the material deployed into space are planned to return to Earth or disposed of in some fashion. The problem debris, as Rixter's chart points out, is typically from something going wrong. The anti-satellite test is the notable exception that has made a bigger mess. It did successfully remove the target satellite but at the price of creating a large fragmentation field that will probably take out others later on.
09/21/2018 1:03 PM
Yes, maybe that should be the question.
" To whom it may concern: We understand that you got the brains to put a vehicle in orbit, but do you got the smarts to clean up your mess afterwards? ".
09/21/2018 11:27 AM
I'm reminded of the old TV show Quark, about a space garbage collector.
09/21/2018 11:16 PM
Does anyone know if you could use the Earth's magnetic field to slow junk down? Maybe by putting an electric charge on the junk, or by attaching an electromagnet to it that is charged by solar energy? It would likely be very slow it it works at all, but would it work at all?
canary
Register to Reply 14 comments
70AARCuda (1); Canary (1); Jpfalt (1); MR. Guest (1); redfred (2); Rixter (4); SolarEagle (1); tonyhemet (2); wrenchtwirler (1)
