Previous in Forum: Encoder Principles: How is Position Established?   Next in Forum: Help to trace out tag missing stator winding wire-125kva Gen set
Brushless Electric Motors for RC
09/27/2007 11:22 AM
I want to operate a ducted fan with about 15-20 oz of static thrust. Motor A will produce the required thrust at full power, drawing ~20 amps at 11 volts and it turns at about 4,400 rpm/volt (no load). Motor B is more powerful, produces about 5,300 rpm/volt and will produce more thrust, if desired. It obviously has heavier gage wiring and less turns of wire around each stator pole, and can draw more current.
My question is for a given level of thrust, is it more efficient (less wattage input) to operate Motor A (the smaller motor) at 100%, or Motor B (the larger motor) at around 75-80%? Both motors are made by the same manufacturer, have the same physical dimensions and parts (except for the stator windings) and should have approximately the same efficiency (I assume).
Pathfinder Tags: ducted fan model airplanes RC
Re: Brushless Electric Motors for RC
09/28/2007 1:18 AM
Larger motor will last longer. Optimum rate will equate to lower mean time before failure. Not nessesarily more efficiency, if they are designed to run at 100% by similar standards.
09/28/2007 10:58 AM
If efficiency (flight time) is important to you, buy both motors and do an experiment to measure the voltage and current while operating using the same ESC and connected to the same load, e.g. a fan at a given RPM. I'm not a motor efficiency expert but it seems in life that if you get more power out of a given package size, the efficiency usually goes down. I suspect you will find that the fewer turns on the stator does drive up the current, but there may be more losses due to magnetic coupling issues. Anybody out there savvy on this kind of thing?
You might want to check out this website:
http://www.peakeff.com/
You might find just what you are looking for.
Good luck with your quest!!
Register to Reply 2 comments
You might be interested in: Motor Test Equipment, Linear Motors, Motor Coils
