Previous in Forum: How can i appply for MCSE   Next in Forum: Has anyone ever programmed their own brain?
Babbitt fluxing and melting
09/27/2007 12:47 PM
On thermal spraying of babbitt bearings sometimes the bearing melts. This is with the use of the Plasma gun. What temperature does babbitt melt at?
Re: Babbitt fluxing and melting
09/27/2007 12:58 PM
I believe there are different types of babbitt, depending on its usage.
United States - Member - NY Engineering Fields - Mechanical Engineering - BSME Clarkson University '83 Fans of Old Computers - TRS-80 - First PC experience Popular Science - Weaponology - New Member
09/27/2007 3:26 PM
ASTM B23 Standard Specification for White Metal Bearing Alloys gives the following melting point values for the various ASTM alloy numbers (in ºF):
# - ºF
1 - 433
2 - 466
3 - 464
4 - 363
5 - 358
7 - 464
8 - 459
10 - 468
11 - 471
12 - 473
15 - 479
16 - 471
19 - 462
09/28/2007 10:38 AM
You do not have to use Plasma Spray for babbitt spraying because the Plasma temperatures are too high. The best method is to use a Wire spray gun and a 3/16" dia wire which can spray almost 60 lbs of babbitt per hour. There will be no melt during the spray. See that the spray is not too fine, because this will mean that the material is oxidizing. Try the fastes speed. I have sprayed bearings of 36" diameter for Hydro-Electric turbines with this proccess, and never had a problem. The equipment is cheap and the application is also very cheap. The normal melting temperature for babbitt is around 450 F If you have any questions, you can e-mail me at vshwn7@aol.com
Good luck
8320 (1); phoenix911 (1); vishmayor (1)
