Previous in Forum: German WW2 Aircraft   Next in Forum: ? on Aluminum Alloy of castings
Is it possible to produce VRLA battery using robust-transparent container?
09/27/2007 10:18 PM
Dear all,
I`m an power supply engineer for Telecommunication for BTS,BSC & MSC in GSM/CDMA operators.As my experience,the VRLA battery have the problem on its capacity due to some problem i.e. undercharge/overcharge,electrolyte inside the battery become dry,positive or negative plate become damage,crystallization/sulphation on plate inside,etc.
Regarding this problem,is it possible to make/produce VRLA battery using robust transparent material?What material used for this robust transparent container? What about the prices? so that we can physically see what`s the problem inside the battery.Even some parameters difficult to be measured such as electrolyte SpGr,but i think the transparent make it easy to make prediction analyze.
Since the Vented Lead Acid battery also use transparent (event not robust),so we can see pre-analyze when vented battery have some problem.
Can anyone from Electrical or chemical or another expert help?
Regards,
Imam Yulianto-Jakarta,Indonesia
Re: Is it possible to produce VRLA battery using robust-transparent container?
09/30/2007 2:24 PM
I am not an expert but I have seen some lead plate batteries in clear housing used for emergency lighting in buildings and for the exit signs.
09/30/2007 10:35 PM
Give the guys at EnerSys a call.....especially speak with people in the Odyssey division....
These are the best AGM's out their.....they would be able to answer your question
09/30/2007 11:29 PM
Do you have the email adress for the Enersys or Odyssey R&D division? Have they produce these VRLA battery using robust transparent container?
Regards,
10/02/2007 5:25 PM
Why not contact the supplier /vendor /manufacturer for solution?
See:
http://www.mpoweruk.com/index.htm
Register to Reply 4 comments
Anonymous Poster (2); Haajee (1); jamesbg (1)
You might be interested in: Battery and Fuel Cell Components, Battery Holders
