Re: What is a Constant Ohmic Impedance Type Transformer?
09/29/2007 2:49 AM
It is a constant ohm trans.. that carries a set impedance of power thru a set of parallel wire windings that is made to not change and if change the opated device (or 's) will not be stable! percision power so to speak!
04/04/2010 10:12 AM
The main reason for adopting the constant ohmic impedance characteristics for all standard transformers was to ensure that there is a constant fault contribution, to the low voltage bus bar regardless of tap position.
