Dear Sir,
I said last week thats i have make one magnetic generator on gravitation force so i have make a hydraulic pump just i want a stock of 10 kg pressure when i push from one side with the force of 5kg so i wants a working pressure another side 10kg, So how can i get the pressure . Once i try but i have get a pressure of that only 9 kg and the hydraulic pump as straight working way the bigger piston and liner size is 12 inch and round the diameter is 7.5 inch and piston size too only .75philler is free in liner and its join with flanch the cone size oil storing capacity in middle its nr storage capacity is 25 Litres and another side cylinder slide is length 24 inch and piston moving in the cylinder size is length 4inch and diameter 3.5 inch and so i am working on this pump now so when i push from big slide at the 5kg pressure so i want from another side woking pressure of 10kg. so how to get this pressure .
