My company is in the primary cobalt metal production business. We run a set of autoclaves into which we feed metallic slurry for pressure leaching. The problem is that the centrifugal pump we use to feed this slurry does not last more than 6 days. The pump is expensive as its material of construction is stainless steel duplex 2205.The flow is 100 cubic metres per hour at 15 bars pressure at pump discharge with the 8 metres level difference.
Is there any pump of better material of construction to handle this slurry? The slurry is composed of Co 5%,Cu 12%, Fe balance, s.g. is 1.3, and temperature is 90 deg. C.. It is:
1. acid due to sulphuric acid(500 mg/l
2. abrasive due to metallic particles(500 microns max).
I will be more than happy to try any thing technically sound that will be suggested.
