Previous in Forum: Star Shape Cracks on Push-Welding Electrode Make Star Shape Weld   Next in Forum: Which CNC is Best for Eyewear Making?
Which Is the Best Way to Weld P11 with P91 Pipes?
10/19/2018 7:30 AM
Dear Sirs, I read several methods to join a P11 [1.25 Cr- 1/2 Mo] pipe to P91 [9Cr - 1 Mo] pipe, such as : 1. Weld using filler metal corresponding to corresponding to [2-1/4Cr - 1Mo] steel & post weld heat treat at appropriate temp.. 2. Butter P91 with filler corresponding to [2-1/4Cr - 1Mo], post weld heat treat & weld with P11 & re-post weld heat treat it. 3. Use a P22 pup piece to join P11 with P91, etc. etc..... However, I wish to know, which is the most appropriate method taking into considerations the overall weld-integrity and high temperature strength of the weldment. Please help to clarify my doubts. THANKS, DDN VERMA
Good Answers: 34
Re: Which Is the Best Way to Weld P11 with P91 Pipes?
10/22/2018 9:06 AM
This problem has been presented to me several times in combined cycle energy plants(MS pipe).
It is possible to weld directly P11 to P91 but it is difficult to approve the corresponding WPS.
The buttering solution is also possible. I recommend doing it with Inox 309.
The best of all is to include a piece of P22 as you mention
10/24/2018 3:30 AM
Thank You very much, Sir Mr. Whitephone,
I am highly obliged to you for your guidance & sharing of the information please.
DDN VERMA
Register to Reply 2 comments
