Over the years, relativity has succeeded in convincing everyone that if you can prove you're the one who's actually moving in a constant relative velocity relationship, then you're talking about an absolute preferred frame. The true meaning is that the only way you can prove you're moving within your own frame is if you feel a force on you. It's easy and irrelevant to prove whether you or the other frame are actually moving and by how much of a percentage over the other guy. Relative velocity remains relative whether you have none or half or all of it and you can depict it as any percentage movement you want. If you're parked on the side of the road, that's irrelevant to the fact if a guy speeds past you at 60mph, both of you still have a velocity of 60mph relative to each other. There's no preferred frame here. If you think it's the earth, each one has a separate velocity relative to it.
The following ralfativity STD shows how, from Alice's perspective (depicted as moving), Bob's depicted stationary perspective is actually moving at the same relative velocity to her. This is a technique that at first I thought was smoke and mirrors but it really works as I'll show in future threads.
The blue horizontal lines are Bob's lines of present and the red slanted lines are Alice's. From Bob's perspective, for 1yr travel (blue lines between 3 and 4) he travels .6 ly (2.4-1.8) which is .6c. Alice's Yv =x/t' for 1 of her years between 3 and 4 is .75lly/1yr =.75c. This is Bob's perspective of how far Alice travels in one of her years.
From Alice's perspective of how far Bob travels in one of her years( between her red 3 and 4), we see Bob's dilated time wrt Alice is between 3.2 - 2.4 = .8 bob yrs. The blue lines from those years lead to how far bob travels from Alice's perspective (1.92-1.44 = .48 ly). .48/.8 = .6c is Bob's velocity through space from Alice's perspective.
Relativity traditionally depicts Alice's perspective of Bob in a separate STD where she is depicted as stationary.
This is completely wrong for so many reasons. First it was shown in Ralfativity pt 1 that space can't move or be moved relative to anything. This was confirmed by the Michelson-Morley experiment. If space was made of water, the MM experiment would have shown a relative velocity to the speed of light through water but it would have also been able to calculate, through the relativistic velocity combo law, the value of c through a voided space.
Space can't move past Alice as the STD depicts. Alice is also depicted as maintaining 0 velocity relative to an empty patch of space for 4 of her years and then takes off at .8824c relative to that empty patch. That's how the depiction keeps her velocity at .6c relative to Bob.
The other problem with this depiction of Alice's perspective is that the bulk of the universe is supposedly moving past her when physically that's impossible. She's the one who accelerated to .6c, not the universe past her. The other reason it's impossible because if Alice is likened to a needle on a spinning record, the needle would have to be anchored to an absolute point outside of the universe. There is no more absolutist view than that.
Perspective does not require it to be labelled as either stationary or moving. Ralfativity allows Alice to be moving and still see Bob as moving as it should be in relative velocity.
At 15:50 of this video
https://www.youtube.com/watch?v=ecXppkuRvig&index=18&list=PLj6DWzIvBi4PFDXCCV1bNhVUgDLTwVbFc
Alice travels through a city and she sees length contraction all around her. Bob only sees her as length contracted. This seems like an imbalance and a preferred frame because Alice is definitely the one in motion. It's very unlikely that she's tethered to another planet passing by earth and the tether is dragging her through this earth city.
Ralfativity says she will not see length contraction because distance is invariant. This means there will be no visible imbalance between the two perspectives. Time is the only thing that bends to maintain c constant from all perspectives.
Please don't bother showing me the wiki articles of the reality of length contraction. I don't know if length contraction is independently a real phenomenon from relativity but it is definitely just an unproven assumption and false construct of the theory of relativity. Length contraction is a product of perspective. It does not survive into reality once the cause of the perspective is removed. Time dilation, on the other hand, is also a product of perspective but, under the circumstances of the twin paradox, it can transition into a permanent reality of age difference.
