Previous in Forum: Helicopter to Fixed Wing Pros and Cons   Next in Forum: Here's How to Watch the Insight Landing on Mars on Monday
Material Information Sources
11/21/2018 1:12 PM
Hi Guys!
I was wondering if anyone could help me!
When looking at a titanium alloy, such as Ti-6Al-2Sn-2Zr-2Mo-2Cr, how can you tell what grade it is. The reason I ask is to help me with a part of a module at university where I need to find information on a range of different materials although im really struggling to find much information at all! The information I need on the alloys are
  • Yield strength
  • Young’s modulus
  • Specific strength
  • Specific stiffness
  • Cost/kg
  • Maximum operating temperature
For the following alloys:
  • Ti-6Al-2Sn-2Zr-2Mo-2Cr
  • 7150-T77511
  • MarM247
If anyone has any information on any of these alloys or can help point me in the right direction that would be great :)
Re: Material Information Sources
11/21/2018 1:26 PM
Most alloys are made to spec for a certain application....You seem to be going backwards....How do you plan to test all these listed properties? How do you plan to test for composition? There is no guarantee that these materials are any specific grade.....?
https://www.olympus-ims.com/en/metal-fabrication/vanta/?gclid=CjwKCAiAodTfBRBEEiwAa1hauuO0QDyqCprig7wyo-QADGZ1_-JJh1FOK5-wkc1HH4cM-_FfjoVJxBoCOJMQAvD_BwE
http://www.supraalloys.com/specs.php
11/21/2018 3:14 PM
Have you sued a search engine?
Are you asking the right questions?
Define "grade."
Titanium Alloys - Ti 6 Al 2 Zr 2 Sn 2 Mo 2 Cr 0.25Si Physical and Mechanical...
Matweb says
Physical Properties
MetricEnglishComments
Density
4.50 g/cc
0.163 lb/in³
Mechanical PropertiesMetricEnglishComments
Hardness, Brinell7070electrolytic Ti
Hardness, Vickers6060
Tensile Strength, Ultimate
220 MPa
31900 psi
Tensile Strength, Yield
140 MPa
20300 psi
Elongation at Break54 %54 %
Modulus of Elasticity
116 GPa
16800 ksi
Poissons Ratio0.340.34
Electrical PropertiesMetricEnglishComments
Electrical Resistivity
0.0000554 ohm-cm
0.0000554 ohm-cm
Magnetic Susceptibility0.000001250.00000125cgs/g
Critical Magnetic Field Strength, Oersted5656
Critical Superconducting Temperature
0.360 - 0.440 K
0.360 - 0.440 K
Thermal PropertiesMetricEnglishComments
Heat of Fusion
435.4 J/g
187.3 BTU/lb
CTE, linear
8.90 µm/m-°C
@Temperature 20.0 - 100 °C
4.94 µin/in-°F
@Temperature 68.0 - 212 °F
10.1 µm/m-°C
@Temperature 1000 °C
5.61 µin/in-°F
@Temperature 1830 °F
Specific Heat Capacity
0.528 J/g-°C
0.126 BTU/lb-°F
Thermal Conductivity
17.0 W/m-K
118 BTU-in/hr-ft²-°F
Melting Point
1650 - 1670 °C
3000 - 3040 °F
Optical PropertiesMetricEnglishComments
Emissivity (0-1)0.630.63unoxidized; 650 nm
Component Elements PropertiesMetricEnglishComments
Titanium, Ti100 %100 %
Descriptive Properties
CAS Number7440-32-6
If all else fails, ask a Ti supplier.
Do your own homework!
Canada - Member - New Member
11/22/2018 8:37 AM
American Society of Materials - ASM International
Prior to the WWW, I purchased most of their handbooks. Every and anything about materials/metals. Google them. I don't know what exactly is available on their website but they will have the information.
Never stop learning
04/16/2020 3:43 PM
As stated above the ASM handbooks are a good starting place, additionally, check out the MMPDS if its for the aerospace industry specifically. Keep in mind that the properties you require are very process dependant, ie what type of raw material is to be used (powder, billet etc.) and how are parts going to be manufactured (formed, milled, cast etc) and is heat treatment going to be performed? Each of these effects the final part properties in various ways. For the specific process you can search for ASTM, ISO, SAE etc. standard specifications which will provide you with the minimum required values for these properties depending on the process and application.
DuncanWilliam (1); Kevin LaPaire (1); lyn (1); SolarEagle (1)
