Previous in Forum: ETAP Recloser Library   Next in Forum: Harmonic Problems in Plant
Question
11/21/2018 5:02 PM
Re: Question
11/21/2018 5:29 PM
Surely you don't want us to do your homework for you.....? Give us the answer, or take your best guess as to how the answer should be written...
https://en.wikipedia.org/wiki/Operational_amplifier
Re: Question
11/21/2018 5:33 PM
Sir I have tried several times but was not able to solve this problem please help.
Re: Question
11/21/2018 5:49 PM
Let's start with part a....What is a differential equation?
Re: Question
11/21/2018 5:51 PM
A differential equation consists of constants and derivatives of various variable functions.
Re: Question
11/21/2018 6:16 PM
Re: Question
11/21/2018 6:27 PM
Here is a similar problem worked from the other direction. Look this over and I believe you will see how to approach your problem.
http://www.niser.ac.in/sps/sites/default/files/basic_page/Solving%20differential%20equation%20using%20OPAMP.pdf
P.S. Hint: Set up your equation for Kirchoff's Current Law at the node for the virtual ground. Sum of the currents will equal zero of course.
Re: Question
11/21/2018 7:25 PM
There are two things you need to know:
1. No current flows into either op-amp input
2. The op-amp will generate output voltage so that both + and - inputs are equal.
Register to Reply 7 comments
Aaryavart (2); Brave Sir Robin (1); Rixter (1); SolarEagle (3)
