Previous in Forum: Affordable biomass pellet machine needed   Next in Forum: Electronic filter "garnet" (YIFG)
10 comments
Tool angle grinder reverse rotation and break
01/04/2006 7:18 AM
kernel writes:
I heard about a new attachment for a handheld angle grinder, which allows forward and reserve rotation. This would be a big advancement over the one way only angle grinder. Where can I buy one? Has anyone ever heard of this new take on an old tool?
Reverse direction
01/05/2006 12:53 AM
There is no usefull advantage to having a portable (hand held) angle grinder with a reverse switch. A fixed (pedastal mounted)angle grinder with a reverse switch also has no advantages as the fly off material cuttings must be diverted away from the operator. It does not make any sense to me why this may be required, the only advantage that I can see is to have the protective cover in a different position. Keep the forces that drive the cutter going away from the operator.
When everthing comming at you, you're in the wrong lane.
Re:Reverse direction
01/05/2006 1:05 AM
if you can direct the sparks away from the operator you can also be able to reduce the chance of kickback by hand held model a brake would allow the operator not to have to slow disc buy pressing down on disc when power is off ever accidently cut the power cords as the machine ran across the floor wheel still spinning?? makes sence to me
angle grinder
01/05/2006 5:32 AM
check your spelling dude, grinders don't reserve rotation. If you reverse rotation, how are you retaining self threaded flap discs? Willey E. Coyote has the patent on this thing, he and the Roadrunner are now living together in Sunny Lakes Retirement Center
angle grinder rotation
01/05/2006 7:13 PM
I guess the left hand threads on the retaining nut will have to change also.This is the most, well maybe not the most ridiculous thing I've heard in a while, but it's right up there.
I love this site.Thanks to everyone that makes it possible.
Re:angle grinder rotation
01/06/2006 8:33 AM
ok, so what happens to the threads when you flick the switch and reverse rotation to the traditional direction?
06/13/2006 12:16 AM
first of all you dummys ...theres no threads to get loose second the brake wont lossen the threads if there are none why reverse rotation you ask??? ever piss into the wind duh
01/26/2014 7:16 PM
of coarse there are threads do you think disc stays on by itself. who the DUMMY
Re: angle grinder rotation
05/09/2010 4:47 AM
Hey all ive just got a new grinder today its the machine marts own 9" grinder I also picked up some metal cutting discs aswell when I used it has loads of vibration im not used to larger grinders so should this be happening ?
Re: Tool angle grinder reverse rotation and break
05/21/2010 11:37 PM
thank you for your opinion.
i have heard that "strong power Tools" Angle Grinder is more useful and hign performance, i have no idea. have you used it before?
05/22/2010 5:06 AM
i have heard that Angle Grinder produced by "Strong Power Tools Co., Ltd" is more useful and hign performance, i have no idea. have you used it before?
The domain "http://www.drill-manufacturer.com"
Allykat (1); Anonymous Poster (3); Grant (1); maniac mechanic (1); PUKO (1); tracygg (3)
You might be interested in: Grinder Pumps, Tool Boxes and Tool Storage, Tool Posts
