Previous in Forum: GIT (Gas injection Technology)   Next in Forum: Castings
Turbine Wheel Run-Out
10/02/2007 5:12 AM
Hi friends,
I want to minimize the problem we are facing in our process line. Actually we are welding one wheel on shaft by electron beam welding after that we are centering the wheel for grinding operation. After that we are grinding that component by clamping the shaft in Colet and tailstock to wheel end.
All sizes and all run outs on part are coming ok but the run out on wheel blade is coming very high. Problem not coming continuously some parts are coming with less run out and some are very high.
So can you advice me for the same
Good Answers: 40
Re: Turbine Wheel Run-Out
10/02/2007 2:45 PM
Sounds like there may be some play in the tail stock.
Is the tail-stock always mounted in the exact same location on the rail? You could have more runout if the tail-stock was extended more and there was even a slight play.
Also check the condition of the tailstock and bearings if applicable.
10/03/2007 5:10 AM
How carefully are you controlling perpendicularity shaft/wheel?
Maybe you want to reference the vanes, themselves.
If you always do what you've always done, You'll always get what you've always had!
10/03/2007 9:18 AM
Hi,
You said "Problem not coming continuously some parts are coming with less run out and some are very high".
Mi question is: are you talking about different part numbers? or do you manufacture always the same part? Because if you talk about different part numbers you should check the tooling you use to produce the wheel.
Have you identified the "unbalance" location on the wheel? It is usually located in the same blade orientation?
I have quite experience in SWA (shaft and wheel assembly) process so may be I can help you if you give more details.
10/03/2007 12:16 PM
It sounds like you are reassembling service experienced parts. I take it you are re-fitting bladed discs to a new shaft?
If these are all new parts then perhaps a review of the blade/disc/shroud production/assembly tolerances is in order.
Need more details to hone a supportive answer.
10/06/2007 4:13 AM
You are removing the run-out of your wheel with your grinding operation. The run-out on your turbine is dependent on the variation of the set-up process you use in your welding process. It sounds like you need to size (manufacture) the wheel and the shaft with somehow fixturing (centering) the turbine end of your assembly so the grinding process is referenced off the turbine. The turbine is probably the most critical part of your process.
RT Pokin
Anonymous Poster (1); rt_pokin (1); SCS (1); sidevalveguru (1); techno (1)
