Previous in Forum: Turbine Wheel Run-Out   Next in Forum: Portable Water cooled Chillers
Castings
10/02/2007 8:40 AM
When precision surfaces are required on a casting, which one of the several types of castings is most likely to need a machining operation subsequent to casting? Which two types are least likely to need subsequent machining?
Re: Castings
10/02/2007 10:27 AM
Most likly to need machining... Sand Casting
least... Die casting
Re: Castings
10/04/2007 4:23 PM
Investment casting is high precision casting - no post machining
Re: Castings
03/13/2008 5:35 PM
Depending on the size of the part and the volume, shell molding or permanent mold castings can be a good compromise between cost and finishing requirements.
Register to Reply 3 comments
