Previous in Forum: loop vehicle detector   Next in Forum: transmitter
Metering Dirty Air Flow in an Air Pollution System
10/02/2007 11:14 AM
I need suggestions as to be best way to accurately meter "dirty" air flow at temps 150 - 300 F. System has a 48 inch diameter main duct. 10ga steel. sytem pressure 10-15 inches WC Chuck
Re: Metering Dirty Air Flow in an Air Pollution System
10/02/2007 11:45 AM
  1. Pitot-tube-and-manometer; do a traverse across the duct?
  2. Ultrasonic flowmeter looking at the velocity echoes coming from the moving dirt particles?
10/02/2007 5:09 PM
Thanks for the prompt response.
Pitot tubes tend to get dirty and thus give false readings. Where can I find a source for the ultrasonic flowmeter?
10/03/2007 9:08 AM
A thought. What if you bleed control air to the pitot tube -- using an adjustable restrictor -- actually you might need two, for Tp and Sp. Enough so that the orifices on the tubes were kept clear. Calibrate the resultant signal against a standard pitot tube for the range of velocities you are interested in.
Good Answers: 19
10/03/2007 9:31 AM
A second thought, install solenoid valves and periodically sequence them to isolate the P transmitters and blow out the pitot statics with compressed air. The shut off the "blow off" air and reopen to the P transmitters. Depending on dirt in system, one or two 15 second blasts should keep the system clean.
10/04/2007 5:46 AM
engineerlicht (1); Howetwo (1); PWSlack (2); Ried (1)
