Previous in Forum: Chimney of Electrical Transmission Tower   Next in Forum: Fuse Selection for Distribution Line
11 comments
Electrical Hysteresis Help
12/10/2018 4:05 PM
Is this what eletrical hystersis
In ferroelectric materials, Relenship between input and output of magnetic feild and voltage. Voltage roduced lapses behind changing magnetic feild.
i dont understand electrical stuff by and tried to piece what i know of hystersis ingeneral.
its for assigment
can understand it
Re: Electrical Hysteresis Help
12/10/2018 5:01 PM
Dielectrics
When you apply an electric field (not magnetic), the molecules in a dielectric are distorted so that the positive and negative charges separate, and more energy can be stored than if the dielectric were not there. This separation of charges is called polarization. The amount of polarization is proportional to the electric field.
Dielectric Polarization
Paraelectrics
Some materials, called paraelectric, have a nonlinear relationship of polarization to electric field. There will be more polarization until the electric field reaches a certain strength, and then they will behave like dielectrics.
Paraelectric Polarization
Ferroelectrics
Ferroelectric materials behave like paraelectric materials except that the material stays polarized after the electric field is removed. When the electric field is reversed, when it becomes strong enough, the material becomes polarized in the opposite direction. If the electric field is repeatedly reversed, the polarization will follow a curve called a hysteresis because the polarization doesn't change until after the electric field is applied in the reverse direction. It is called ferroelectric because it behaves the same way that iron behaves in an alternating magnetic field.
Ferroelectric Polarization
https://en.wikipedia.org/wiki/Ferroelectricity
12/10/2018 5:18 PM
hey thanks
can i just check i understood
so hystersis electrical would be
in Ferroelectric materials, in which the the polarity (storage of charges) lags behind the change in eletric field . when it repeat . it retain degree of polarity
12/10/2018 10:26 PM
Exactly!
12/11/2018 2:23 PM
thank you so much
ive been at that so long making want to go insane
you have no idea how much u made my day
thank you
12/10/2018 5:33 PM
12/11/2018 5:41 AM
sorry just started my hnc in engineering and electrical the worst part for me
is this right
a current is applied a magnetic field is generated. current is reversed zeros its repeat. metal maintains degree of magnetizem dipole aligment. the magnetic feild lags behind the current change. producing electreical hystersis loop.
12/10/2018 6:22 PM
Think of it this way.
Electrons have no mass and can change polarity instantaneously.
Ferro fluid particles have mass and cannot change polarity instantaneously.
12/11/2018 4:46 AM
is this right
energy is lost as heat causing wire to heat up causing causing low effiency
12/11/2018 5:23 AM
12/11/2018 10:22 AM
Example of mass of an e at rest:
https://cr4.globalspec.com/comment/13761/Re-E-mc-2
12/15/2018 3:55 AM
i think i got it know just checking, tried to word it differently each
In ferroelectric materials, Relenship between input and output of magnetic feild and voltage. Voltage roduced lapses behind changing magnetic feild. Present in metals.
in Ferroelectric materials, in which the the polarity (storage of charges) lags behind the change in eletric field . when it repeat . it retain degree of polarity.
Register to Reply 11 comments
Jose1 (1); lee1234 (5); lyn (1); Rixter (2); SolarEagle (2)
