Previous in Forum: Surge Capacitors   Next in Forum: Electrical Hysteresis Help
Chimney of Electrical Transmission Tower
12/07/2018 9:36 AM
Dear Sirs,
What is the 'chimney' of electrical overhead transmission tower?
Best Regards,
Re: Chimney of electrical transmission tower.
12/07/2018 9:47 AM
It is, among other things, an ideal topic for an internet search engine to play with.
Re: Chimney of Electrical Transmission Tower
12/07/2018 11:47 AM
Can't we have a section titled "I don't want to use Google so..."?
I didn't know I want to know, but now I know that I too want to know about transmission tower chimneys..?
..makes one 'well rounded'.
however, I think there may be a disconnect
.. here it is
12/07/2018 12:41 PM
A chimney is part of the foundation for supporting transmission lines.
https://nptel.ac.in/courses/105106113/8_foundation_of_towers/5_structural_arrangement.pdf
Reply Good Answer (Score 4)
12/07/2018 3:47 PM
Who knew a proper answer would be forthcoming? GA
12/07/2018 9:20 PM
The do resemble chimneys in many cases.
12/10/2018 3:17 AM
Chimney means the metal tower which build for carrying electrical wires..These chimney are the main support system of whole transmission system..If you want more information then you can search on google also
Online Electrical Design Training
01/21/2019 5:43 AM
The purpose of the foundation is to transfer the loads from the structure to the ground without causing the ground to fail in shear or to allow excessive settlement to the structure to occur.
These requirements are met by ensuring the bearing pressure below the foundation does not exceed permissible bearing pressure.
The purpose of this calculation is to design Pad & Chimney foundation for "A10" type lattice steel tower structure.
The foundation is subjected to upward, downward and horizontal forces.
Foundation loads will be obtained from the tower reactions multiplied by over load capacity factors.
These factored loads will be used in the sizing of the foundation. However, to design steel reinforcements reactions without the OCFs will be used.
Brave Sir Robin (1); JE in Chicago (2); pranus (1); PWSlack (1); Rixter (1); sha664817 (1)
