Previous in Forum: Seth Putterman "Fiat Lux" Link   Next in Forum: Bizarre "Dark Fluid" with Negative Mass
Chimney Leak?
12/16/2018 5:14 PM
Is it possible for my chimney stove pipe to leak at the roof and water to gather in my ceiling? three story house and flashing on roof appears that hurricane winds blew lower side up and loose. had a lot of water in 1st floor ceiling after a heavy rain several days after hurricane only thing i can find that seems to need repair....
possible?
Pathfinder Tags: stove pipe chimney
Re: Chimney leak?
12/16/2018 5:42 PM
Hurricane force winds can force water into small cracks that normally wouldn't leak, but does expose weak spots and places that need repair....It's a good idea after a hurricane to look for any water that has entered the house, including walls, windows, attic space etc, and start your repairs...It appears you have exposed a problem area around your chimney, any irregularity is a potential leak...seal it up
Re: Chimney leak?
12/16/2018 8:33 PM
Possible? Yes.
During a hurricane? Absolutely!
Seek professional help.
Re: Chimney Leak?
12/17/2018 3:47 AM
Yes, with time it is a certainty...
These things need maintenance, even on a brick built property.
https://bowyersdiary.blogspot.com/2015/08/non-bow-related-activity.html
Re: Chimney Leak?
12/17/2018 8:37 AM
Yes, it is possible.
Leaks are never merely cosmetic. Leaks are always a structural concern.
Re: Chimney Leak?
12/17/2018 12:13 PM
Here is a good link that will show you how it should be done:
https://www.familyhandyman.com/roof/installing-chimney-flashing/view-all/
Good luck!
Re: Chimney Leak?
12/17/2018 12:52 PM
Possible,... bring a couple sticks of tar for repair... or any other type of sealant
problem with a leak, it could draw and run from the actual point where it leaks.
i suppose there’s not a way to the attic to see.
Re: Chimney Leak?
12/18/2018 8:16 AM
YES
Register to Reply 7 comments
HiTekRedNek (1); lyn (1); mikenelson6 (1); phoenix911 (1); SolarEagle (1); truth is not a compromise (1); user-deleted-1105 (1)
