Previous in Forum: Pressure (dePa)   Next in Forum: Pipe Shaping
T Size Gas Cylinder
10/05/2007 2:40 PM
Can someone give me the exact dimensions (spefically diameter) of a t-size gas cylinder?
Good Answers: 19
Re: T Size Gas Cylinder
10/05/2007 2:57 PM
Common Cylinder Storage Capacity. External Dimensions. D Size. Ø175 E Size. Ø215. G Size. Ø250. G Size. Ø375. Acetylene. T Size. Ø310.
Go to site: www.walshengineering.com
10/05/2007 3:42 PM
Google: gas cylinder sizes
Results 1 - 10 of about 2,570,000 for gas cylinder sizes. (0.18 seconds)
10/06/2007 12:33 AM
T size is I believe a Praxair "size", but in fact it is the same as a Scott K size, an Airgas "300", an Air Products "A" size or an AGA "49".
Capacity is 48.99 Litres of water and diameter is 9.25" with a nominal weight of 143 lbs roughly 65 kilos. Height 61 " (with cap) 55" without cap. Internal volume is 1.730 cft.
The ID I don't know. I believe the 9.25" dimension is the OD of the cylinder.
10/06/2007 3:44 AM
ID254mm,OD270mm,L1473mm,WT84KG,VOL 66lts, service pressure 154bars,test pressure 250bars.
regards
moin
Anonymous Poster (1); ducon (1); Raknruin (1); TexasCharley (1)
