Previous in Forum: doubly fed induction generator   Next in Forum: vfd motor-torque & power characteristics
10 comments
India - Member - PROFESSIONAL Engineering Fields - Power Engineering - electrical planning - designing
The Neutral grounding for Power transformer
10/06/2007 2:05 AM
Please share your valuable views for advantage / disadvantage for :-
The application of , The Neutral solid earthing OR with resistance earthing on 66kv/ 11 kv 3 phase dyn 25 MVA transformer The seondary load are Induction motors .
nascon
Egypt - Member - Ahmad Samak
Re: The Neutral grounding for Power transformer
10/06/2007 7:05 PM
For medium voltage network, the solidly grounded neutral is not preferred, grounding through resistance is preferable in order to reduce the ground fault current in comparison with the solidly grounded system. That is regardless of what type of load is connected to the transformer.
Another question comes up now, is it better to use an isolated transformer (ungrounded)?
in special cases (Yes), but with a drawback of high voltage attack, usually cased by sorts of switching transient.
See Chapter 1 of IEEE standard # 142 - 1991
I have an e-copy but I don't know how can I attach it...
Good Luck... Samak
10/07/2007 4:02 AM
Despite grounding resistance a coil, so called Petersen coil is generally used to ground the neutral point. Normally there is no current over this coil but in case of any error it emphasises the error current and makes the job of protection easier.
Aged man is not old man...
10/07/2007 10:55 AM
hi i m nandita.i read ur views about neutral grounding.u also talked about the related ieee std. can u pls send me a soft copy of the same at my e-mail id: nandu_rm@hotmail.com .
10/07/2007 3:01 PM
10/08/2007 12:10 AM
Thnaks.
The attchment u can send by e mail on
niranjan.shastri@yahho.co.in
nascon
10/08/2007 1:53 AM
hi samak
could u pls attache the E-copy of Chapter 1 of IEEE standard # 142 - 1991 to dis id manirul.islam@neilsoft.com
10/08/2007 11:56 AM
Can you please send me the said e-copy at solaaderinwale@yahoo.co.uk.
One does not need a mirror to look at what one is wearing on the wrist
10/08/2007 4:10 PM
Dear Friends:
IEEE 142 is a 10 Mbyte pdf file... may you recommend me another way to submit this file as it is too big to be attached with an email.
I'm a member of windows live messenger. It may be used to transfer that file.
However, you can add my email to your body list if you are a member.
Good Luck... Ahmad Samak
11/20/2007 1:46 AM
HI , Mr ahmad
I am ahmed yuonis , postgraduate student , garyounis univercity , libya .
please try to send the ieee.stand. for grounding power transformers to my email
becuse my interest field in this subject.
thanks
my email : alorfi69@yahoo.com
11/20/2007 1:57 PM
Dear Ahmad
I live in Alexandria, Egypt.
I'm glad to meet you, I spent 3 years in El-Zawya while I was 8 years old.
Please, read post # 8, my email is samak@alexandria.cc
Regards
Samak
Register to Reply 10 comments
Anonymous Poster (3); nascon (1); Qqberci (2); Samak (3); solaaderinwale (1)
