An artificial, bio-inspired leaf. Carbon dioxide (red and black balls) enter the leaf as water (white and red balls) evaporates from the bottom of the leaf. An artificial photosystem (purple circle at the center of the leaf) made of a light absorber coated with catalysts converts carbon dioxide to carbon monoxide and converts water to oxygen (shown as double red balls) using sunlight. Credit: Meenesh Singh
https://www.sciencedaily.com/releases/2019/02/190212160020.htm
"According to their calculations, 360 leaves, each 1.7 meters long and 0.2 meters wide, would produce close to a half-ton of carbon monoxide per day that could be used as the basis for synthetic fuels. Three hundred and sixty of these artificial leaves covering a 500-meter square area would be able to reduce carbon dioxide levels by 10 percent in the surrounding air within 100 meters of the array in one day."
These artificial leaves, apparently, can remove CO2 at atmospheric concentrations. The only problem I see is what to do with the carbon monoxide. If it's used for synthetic fuels, it would seem that the carbon would just end up as atmospheric CO2 again.
