Previous in Forum: tyers recycling   Next in Forum: mistshubishi vfd
how to produce secateur cutting blade
10/06/2007 9:40 PM
what are the manufacturing steps performed to produce secateur cutting blade?what are the tolerances that would justify the manufacturing process?
Pathfinder Tags: blade
Re: how to produce secateur cutting blade
10/07/2007 9:14 AM
Forging and then grinding I guess...
Maybe case hardening as well... ??
10/08/2007 12:49 AM
"what are the manufacturing steps performed to produce secateur cutting blade?what are the tolerances that would justify the manufacturing process?"
The design and fabrication/production is highly dependent on the material and thickness to be cut. Since we are not mind readers you will have to be more specific unless this is a secret or classified project in which case you are on your own.
Register to Reply 2 comments
You might be interested in: Cutting Services
