Previous in Forum: Transmission Line Leg Profile   Next in Forum: Protection of Uphill Slope
Transmission Line Earthing
02/18/2019 10:03 PM
Dear Sirs,
It appears that counterpoise wires are used parallel to the transmission line in order to reduce the earthing resistance and also the potential between the conductor and tower top.
But countepoises are also used at 45 degrees to the transmission line, and also at 90 degrees to the alignment of the transmission line. Why?
In case of single counterpoise wire, parallel counterpoise wires are also used?Also, where are radial and ring-type of counterpoises used?
If the tower footing resistance is not achieved by say 25 metres of counterpoise, then the length is increased to 50 metres or 70 metres?
Best Regards,
Re: Transmissin Line Earthing
02/19/2019 3:42 PM
What happens when you drop a rock into the water?
Good Answers: 42
Re: Transmission Line Earthing
02/20/2019 11:24 AM
In my opinion the answer it is a bit more complex. See for instance:
https://www.researchgate.net/publication/3275110_Effective_Length_of_Counterpoise_Wire_Under_Lightning_Current
Julius
