Previous in Forum: couplings   Next in Forum: Asphalt or 3LPE to Coat Undersea Steel Pipes?
Bandsaw blade
10/07/2007 3:54 PM
I have a band saw machine used to cut the HRC of X70 grade material, i am using HSS blade, also i am supposed to change the blade atleast once in 24 hours, so i am investing more money for this. Anyone kindly say me that, what blade (material) should i use of this HRC material.
Re: Bandsaw blade
10/07/2007 11:50 PM
Change to Electric Arc Saw.
Re: Bandsaw blade
10/08/2007 3:16 AM
a rockwell of 70 will not saw pitiod
grinding abrasive cut off or diamond wet saw
electric plasma is not good it will rnuien the material
get a copy of machinres hand book
Re: Bandsaw blade
10/08/2007 6:26 AM
water jet cutting machine
Re: Bandsaw blade
10/08/2007 9:08 AM
If cutting with bandsaw is your only option use a bandsaw blade with solid carbide tipped teeth.
ONE TEST IS WORTH A THOUSAND EXPERT OPINIONS
Good Answers: 266
Re: Bandsaw blade
10/08/2007 10:07 AM
replace the saw with cut off saw with variable speed motor. you can get circular saw blades with cermets tips instead of carbide. with a controlled feed will 2 to 3 times the life of carbide and about 10 over high speed steel.
Re: Bandsaw blade
10/08/2007 4:04 PM
It seems that I am often in agreement with the ozzb on such issues. no exception here.
chopsaws, radial arm, band etc are all pretty cheap for general applications. Some experimentation might help.
Perhaps calling around to other companies/competitors to see what they are doing.
cr
Register to Reply 6 comments
Anonymous Poster (1); erssk (1); MUKULMAHANT (1); ozzb (1); TexasCharley (1)
