Previous in Forum: Steel Plate Accelearated cooling vis-a-vis Quenched & Tempered Plates   Next in Forum: Stainless Steel Welding
forging
10/08/2007 12:46 PM
Failure of a Tractor Spindle
A front wheel axle spindle on a tractor became damaged from a bearing failure. A replacement part would take 6 weeks to get if it was ordered from the factory, and the farmer needed the tractor for his spring planting. A new spindle was made at a local machine shop from solid steel of the same alloy as the original. After 2 weeks of use, it broke in half and the wheel fell off. Considering what you have learned in this chapter, what do you thing caused the failure of the machined spindle?
This discussion was "closed" on 10/08/2007 1:25 PM. No new comments are allowed.
Friend of CR4
Re: forging
10/08/2007 1:26 PM
CR4 is not a homework cheat site. While some here might relish the opportunity to sharpen up old rusty skills by working the homework problem, consider this and consider it well. If you cheat on your homework by using someone else's answers, you are only cheating yourself, because the purpose of any homework or other college assignments is to help you learn, by practice, repetition, and self-discovery.
http://cr4.globalspec.com/faq#faq14a
If you have any questions, please feel free to contact the CR4 Admin.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
