Previous in Forum: forging   Next in Forum: Treatment for the water from paint spraying booth
8 comments
Stainless Steel Welding
10/10/2007 8:30 AM
hi, who can tell me what kind of oxide will be taken when we weldin stainless steel alloy (pipe) without purching ineri gas.
Re: Stainless Steel Welding
10/10/2007 12:25 PM
There is a lot of discussion re: discoloration of weld joints where unclean gases are used. Obviously a purge gas keeps a positive pressure so to create a smooth joint but it also keeps contaminates out of the joint as well.
Typical orbital welding of high-purity systems employs GTAW (gas tungsten arc welding) for its cleanliness, repeatibility and speed using either five nine Ar or N from a purified source and a point of use filter.
I have been through countless meetings and evaluation sessions as to how these impurities effect product integrity. No one has ever come out and said "OK, this is the chemical makeup of the halo, or yellowing at the joint".
Please tell me what you are piping (product) and what your welding equipment is and I may be able to elaborate.
cr3
01/06/2009 7:18 AM
is it nessasary to purge weld in 19-15 stainless steel smaw welding
10/10/2007 3:28 PM
I guess a point worth noting is use of INERT gas. It is nonreactive, nonflammable and noncorrosive.
We wouldn't want to try and weld with silane or oxygen as a purge gas, now would we?
cr3
10/11/2007 8:57 AM
If you have no gas available, Why not use self sheilding process like SMAW?
ONE TEST IS WORTH A THOUSAND EXPERT OPINIONS
10/11/2007 1:36 PM
The purpose of the gas is to keep hydrogen and oxygen out of the joint. Chrome in stainless is to pick up carbon to keep it corrosion resistant. Oxygen can form with many elements with higher bonding affinity contaminating the weld with porosity etc.
Hydrogen will embrittle the joint through atomic to molecular change upon cooling.
Use argon as your shielding gas.
No gas - big problem
If you do not have access to gas then use chromium/stainless welding rods that generate their own gases to shield the weld.
Tig is cleanest method though
10/11/2007 3:04 PM
argon is not required. It depends on how clean you want the joint.
For welding e.p. or b.a. tube GTAW is the preffered/required method for mainting system integrity. And, five nine Ar internal & head purges are required.
Parameters such as
.1micron particles<10 ppb
trace gas analysis at a low ppt level
helium leak at <10E -9
10/11/2007 8:57 PM
I like using a tri-mix .... CO2-Argon and a touch of helium.
The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair...Douglas Adams
10/15/2007 1:42 AM
Hi Guest,
Please tell us the kind of weld: ARC or MIG or MAG. And the size with thickness of stainless steel pipe was welded.
best regard
Nature is unlimited, human's knowledge is limited
Anonymous Poster (2); erssk (1); nam70 (1); TexasCharley (3); wgh71 (1)
