Previous in Forum: Killing Flat Earth   Next in Forum: Where Have all the Posters Gone?
21 comments
Underwater Speed Humps and Dehydrated Air Bubbles
04/07/2019 8:09 AM
Under water speed humps and dehydrated air bubbles.
We recently completed the installation of under water speed humps at the entrances o the Suez Canal. The speed humps assist in slowing shipping and pleasure craft down to allow an orderly approach to the lock gates at both entrances to the canal.
On the Mediterranean side, three speed humps were required due to the water flow being in a downhill flow from the Mediterranean into the Red Sea, which then flows into the Gulf of Aden and the Indian Ocean.
On the exiting side of the canal, 4 speed humps were installed across the narrowest section between Djibouti and Yemen, two on either side of the narrow gap between the two continents of Africa and Arabia. One set installed between Rahayta to Dhubab, the second set installed from Khor’Angar to Al Bahiyah in the Bad al-Mandad Straits. The result has been the reduction of erosion along the coastline and beeches Perim Island, cause by ship wash and the reduction of near collision with the sparsely populated island of Socotra in the Arabian Sea.
The speed humps were installed as one continuous humps and deployed using local labour and a specially designed ship for use in various types of seas. Once the initial cup end was securely anchored on the beech side the hump was slowly unwound from the carousel, installed on the ships deck, and using a series of pulleys and skids and water speed hump gantries, the speed hump was unwound and floated onto the sea surface. Given various tides and currents at the time, the seed hump was inflated with water and an air mixture of nitrogen, ozone, and Co2 gases, then securely anchored on the opposite shore.
In order to assist shipping and pleasure craft ensure the reduction of speed, the speed humps are protected at a distance of 4 km by dehydrated compressed air bubbles which are released into the sea by use of micro boats, which autonomously patrol the speed humps. The micro boats function both above and below the water level, utilising both solar and hydrogen cells to power the electric motors tat drive them. The solar cells assist with compressing and dehydrating the required air, which is forced through graduated filter mesh’s, then super heated to create flakes of air, which once released into the sea water, slowly sinks, and in doing so absorbed water to rehydrate, forming an air bubble, which rises to the surface, creating positive bouancy for shipping and increasing the fish population with the speed hump barriers.
This has been made possible by crowd funding and assistance from the American people of Knoxville and Pennsylvania Over Seas Development Funding programme, as well as the Eritrea Industrial Labour Council for Wealth and Welfare. This has created employment along the coast and canal, having employed 102 persons on full time employment and has assisted local fishermen to remain safe in this busy shipping channel.
The Mediterranean coast speed humps are anchored at Port Said to Hiafa, however, with current tensions around the Israeli coast line and the new presence of US warships, it was deemed that the dehydrated compressed air bubbles (DCAB), may create an interference with sensitive ship hull devices such as propellers, causing cavitation or possible clogging of bow thruster. It was noted during extreme testing that the DCAB, when released at deeper levels, caused additional buoyancy in the water and submarines easily popped to the surface.
Further funding will be envisaged to allow local production, on shore, of the dehydrated compressed air bubbles and for the on going maintenance of the water speed humps. To date, shipping accidents have been reduced, island beech erosion has reduced by 37.8% and fish populations have seen a dramatic increase, with some new species appearing, that were once thought to have been abundant in the region.
DCAB are now being considered for carbon capture and test are being conducted by the Australian Institute of Dugongs and Wombats in Port MacQuarrie. The result will be available November 2019.
Re: Underwater Speed Humps and Dehydrated Air Bubbles
04/07/2019 11:28 AM
This appears to be pure fiction, what is your point?
04/07/2019 1:39 PM
Staying anonymous, it would seem.
04/07/2019 3:09 PM
Probably bubbles of bolonium sulfide (BS) gas...
04/07/2019 2:42 PM
" Australian Institute of Dugongs and Wombats in Port MacQuarrie."
Did you mean the "Australian Institute of Dingbats in Port MacQuarrie?"
04/07/2019 5:40 PM
Interesting, I partially watched a documentary last week on this installation, never gave it much creditability, but it seems to be working. The documentary stated they were considering this at the Panama Canal if the Red sea trails are successful. Who would have though, speed bumps in the sea!
04/07/2019 6:37 PM
I understand they employed mermaids for the underwater work, is that so?
04/08/2019 9:09 AM
My mistake, it was floating barriers for capturing flotsam around harbours. I assumed that this was the gist of the text.
04/14/2019 7:59 PM
"... floating barriers for capturing flotsam around harbours. ...."
Perilous entrances (or wildly reckless (wreckful?) navigators) those harbors must have to require special barriers just for the capture of flotsam.
04/07/2019 7:00 PM
I eat dehydrated air flakes for breakfast
04/07/2019 9:32 PM
Underwater speed hump throws fish into boat ...
04/08/2019 12:12 PM
That was a great swap, one swordfish for one fisherman. So perhaps the mermaid who laid the speed humps got her man. Still a great swap though.
04/08/2019 12:03 AM
This was posted almost a week (six days to be exact) late. There's no fool like an old (or late) fool.
clint.bowman@comcast.net
04/08/2019 2:47 PM
"Hurry or you will be late."
"Late for what?"
"What is your name"
"Anonymous"
"Late as in the late anonymous". "It's some sort of threat. I'm not very good at them though."
04/08/2019 9:31 AM
Which Knoxville? Wikipedia lists 12 in the U.S.
04/08/2019 12:31 PM
April 1st was a week ago.
04/08/2019 2:42 PM
Six days late and a bitcoin short.
04/08/2019 4:13 PM
Humpback whales may have underwater speed humps.
04/09/2019 1:04 PM
I think most whales have underwater speed humps.
04/08/2019 4:15 PM
04/08/2019 5:57 PM
I hope it's non-GMO . . . .
04/09/2019 1:09 PM
And gluten free.
Reply to Forum Thread 21 comments
BestInShow (1); Brave Sir Robin (2); clint420601 (1); IQ (3); JE in Chicago (1); Jpfalt (3); lyn (1); PWSlack (1); Rixter (1); SolarEagle (3); StandardsGuy (2); truth is not a compromise (1); XNuke (1)
