Previous in Forum: Displacement Settlements. Surface Water Management   Next in Forum: Any Tips on How to Solve This Question?
28 comments
My Wits End
05/02/2019 5:18 AM
Coming from a hands on mechanics background I can do my own repairs and maintenance of diesel powered tree stump grinders. For those unfamiliar, these machines while fairly basic in design are truly "at the coal face" with an intense hostile gritty environment. As a consequence, bearing life is comparatively short with say those used with conveyor belts. OEM (Rexnord-Link Belt) spherical roller pillow blocks being used to support the grinders cutter wheel are great bearings designed with a threaded collar to be screwed in to take up excessive play owing to fair wear. This allows a longer service life than non adjustable bearings. Cutter wheels on these stump grinders are subjected to high vibration, high shock loads, in an extreme gritty environment. My issue is with replacement costing. I have unsuccessfully been searching for an alternative (lower cost) bearing with the same wear compensation adjustment. It looks to me like Rexnord- Link Belt has the market sewn up regarding this feature, and is charging a high replacement price as a consequence. Is anyone out there aware of a comparable pillow block.
You can't always sometimes tell what you least expect mostly----Mike Lish
Re: My Wits End
05/02/2019 5:54 AM
Well you don't mention any details... ie: shaft size, part nos, price paid, grinder type and model........found this though
https://www.arboristsite.com/community/threads/vermeer-630a-pillow-block-bearing.205817/
Re: My Wits End
05/03/2019 8:13 AM
Thanks for the link. I will happily pay $125 per bearing compared to the wild quotes I've received $303 - $356 here in rip off U.K.
Re: My Wits End
05/03/2019 8:45 AM
PB22423H 1-7/16" bore. I will happily pay $125 compared to the rip off range of prices I received ($303 - $356)
Good Answers: 145
Re: My Wits End
05/02/2019 7:03 AM
Specifications and pictures are often helpful, especially for the "off the wall" suggestions. Someone might come up with a suggestion for a standard bearing (lower cost wear item) and a custom gadget for adjustment (one-time acquisition, low wear).
Good Answers: 181
Re: My Wits End
05/02/2019 8:38 AM
SKF and others do double taper bearings that you can tighten to take up slack.
Not cheap but there again I don’t know what you’re using now.
Re: My Wits End
05/03/2019 9:00 AM
As explained in my initial posting I need an equivalent bearing that offers a wear compensation adjustment as does Rexnord-Link Belt but at a lesser price. Here in rip off U.K. I am getting quotes ranging in price $303 -$356+ (£233 - £276+) for PB22423H Rexnord bearings. They seem to have their market sewn up.
Re: My Wits End
05/03/2019 7:07 PM
Contact the person at this link and describe your particular needs.They do offer their bearings in standard inch sizes. Perhaps this guy can help you.----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Sorry I cannot post a proper link,just cut and paste. https://www.igus.co.uk/myigus/default.aspx?page=form_contact&adre=464
Re: My Wits End
05/02/2019 8:42 AM
Look for replacement substitute from Timkin Bearings. They are a world leader in all types of bearing,including mining,conveyors,etc.
A bearing number will be VERY HELPFUL.
Re: My Wits End
05/02/2019 12:08 PM
Re: My Wits End
05/02/2019 2:08 PM
Hmmm, maybe you just need a bigger grinder....?
Re: My Wits End
05/03/2019 8:51 AM
Its somewhat difficult getting these into back yards!
Re: My Wits End
05/03/2019 4:16 AM
I saw an article about this recently referring to IGUS replacements. See www.igus.co.uk/igubal
"Motion plastics specialist igus introduces igubal spherical balls that can be inserted into existing metallic pillow block and flange bearing housings within a few seconds. These bearings, which are often used in construction machines and conveyor systems, are exposed to harsh environments requiring regular lubrication and maintenance. The igubal spherical balls are injection moulded in the high-performance plastic iglidur J, which is self-lubricating. The retrofitted bearings therefore are maintenance-free. Another advantage is that due to the absence of lubricant, dirt and impurities can no longer adhere to the bearings. Thus, there is no long downtime of the machines and plant for maintenance.
The long service life of the igubal spherical balls has already been proven in a biomass chipper. The original metal bearings on the conveyor belt of the machine had to be lubricated each month. When the flange bearings were retrofitted with igubal spherical balls, the bearings remained wear-free for more than a year, without the need for lubrication and maintenance."
Re: My Wits End
05/03/2019 7:41 AM
Thanks for the great link.I am always interested in new technology.I have seen dry UHMW bearings in dirty,abrasive and harsh chemical environments out last many lubricated bearings in same application. The IGUS bearings appear to be a combination of UHMW,or similar polymer,plus nano-embedded coating,and embedded lubricant.Forest mulchers are very high maintenance because of the harsh environment and high wear of all components.Most skid steer mulchers are sold for parts at around 3000 working hours,or need a complete overhaul. The low clearance requirement helps to exclude dirt, and any dirt that does enter is embedded into the base coat and does very little damage to shaft. When dirt enters a grease lubricated bearing,it mingles with the grease and grinds away at the rollers and races,like a grinding compound. I will try the IGUS bearing myself when the need arises.
Re: My Wits End
05/03/2019 8:04 AM
Sounds like a great bearing for conveyors, but as previously explained for a stump grinders cutter wheel that is subjected to intense grit, vibration, and shock loading, I have my doubts as to its suitability.
Re: My Wits End
05/03/2019 8:31 AM
Unfortunately, these Igus bearings max out at 30mm and are not offered in imperial sizes. I am running 1-7/16" shafts and to convert over to metric is cost prohibitive.
Re: My Wits End
05/03/2019 7:09 AM
I use Rexnord - Link Belt PB22423H pillow blocks. Below is the response to my question about Timkin I received from a UK supplier.:
Clive Simkins <clive.simkins@acorn-ind.co.uk>
08:57 (2 hours ago) Reply
Hi Mike,
"Just to clarify the differences between the Rexnord Housed unit and Timken alternative.
Although the Timken unit has the facility to adjust the bearing from a ‘fixed/located’ to a ‘free/unlocated’ it does not have the same facility of the Rexnord unit of altering the bearing seating owing to wear.
The only comment on this would be that depending on the amount of wear would question for how long the bearing could operate successfully afterwards.
With regard to the base to centre of shaft measurement comparisons:
Rexnord – 47.625mm
Timken – 47.8mm"
Regarding Clive's comment, "would question for how long the bearing could operate successfully afterwards." --- is just a smoke screen to put some doubt in my mind so he can sell me Timkin when to my experience Rexnord's wear compensatory adjuster has more than doubled the service life. In fact I disassembled a bearing to inspect the rollers and races for fretting, brinelling, etc. after having run out of any further wear adjustment, and found nothing apart from obvious wear.
If Rexnord has indeed cornered the market with this particular wear compensation feature I will pay their price, but just put out the question is their an alternative with this feature.
Re: My Wits End
05/03/2019 10:54 AM
Have you given any thought to making up a pair of housings that would accept back to back automotive tapered roller bearings? Load is high, adjustment excellent and wheel bearings are generally dirt cheap.
Re: My Wits End
05/03/2019 1:25 PM
Maybe you should just soften up the stumps a little before grinding...
Re: My Wits End
05/03/2019 1:33 PM
Project Gutenberg has a book available from Dynamite Nobel entitled "Farming with Dynamite" that includes such procedures not only for removing stumps, but also for high speed hole creation to plant new trees.
Re: My Wits End
05/03/2019 1:45 PM
I think the key is to drill in the ground beneath the stump....seems more effective at taking a deep bite....
Re: My Wits End
05/03/2019 2:19 PM
How to remove big whales....
Re: My Wits End
05/07/2019 10:13 AM
Here is a link to a Rexnord surplus page. Maybe this will help. gonna have to cut and paste. ====================================================================================================================================================================================================================================================================https://hebeama.com/p-b22423h===============================
Re: My Wits End
05/07/2019 4:12 PM
I dug a little deeper on the Igus bearings and they are not suitable for your application,the shaft speed is too high. I am wondering if the bearing wear you are experiencing is due to dirt entry into the bearing. Are the Rexnord bearing seals triple -lip seals?I think you need a shieldedand sealed bearing. I do not know if this is applicable,but there are Bearing Buddies available for boat trailers.They provide a constant supply of grease to a bearing under a slight pressure..not enough pressure to damage the seal,but enough to keep out external contaminants.You may be able to find a suitable size for your application. At a bearing seminar,many years ago,provided by Fafnir Bearings ,we were told that the number one cause of bearing failure is Over greasing. More than dirt!It was very hard to believe,but it was explained. According to them,over greasing of a bearing will not allow the grease to get out of the way,and it will churn the grease,causing a heat buildup which will turn the grease into carbon,which in this condition, is hard and has no lubrication properties.Bearing failure will result. Too much grease can also cause seal failure and allow contaminants into the grease. I know if you own the equipment,you take very good care of it,but greasing can be overdone. I have still got my feelers out for a replacement for the Rexnord,so don't give up just yet.
Re: My Wits End
05/07/2019 7:03 PM
Here is a link for substitute replacement bearings:======================================================================================================================================================= https://www.thebigbearingstore.com/1-7-16-m2000-heavy-duty-two-bolt-pillow-block-bearing/ Good luck!
Re: My Wits End
05/09/2019 6:30 PM
... And just how did this Mechanical Engineering question come to be posted in the Civil Engineering Section ?...
Re: My Wits End
05/09/2019 7:49 PM
Stumps is wood.
Stump grinders turns them into chips.
Chips can be made into OSB.
OSB can be used to make buildings or crate up exploded whales.
That makes it civilized engineering.
Re: My Wits End
05/10/2019 4:54 PM
Wooden stumps consist of wood cells...
Re: My Wits End
05/30/2019 1:29 PM
Check with these people in the following link regarding rebuilt bearings.They can rebuild cost for about 60% of the cost of a new one,and they are as good as new.
Do you have any old used bearings to send to them?
http://scheererbearing.com/uploads/pdfs/Scheerer_Bearing_Rebuild_Recondition.pdf
Register to Reply 28 comments
BruceFlorida (1); DaveD (1); emellish (7); HiTekRedNek (7); Jpfalt (4); lyn (1); MR. Guest (2); SolarEagle (4); TonyS (1)
