Previous in Forum: Heat Load - ASHRAE Standards   Next in Forum: Casting Methods For Stainless Steel
Ansys: Creating a simple extrusion from a 2d shell element shape
10/11/2007 6:37 AM
I am attempting to extrude a simple 2d shape with shell element 63 in Ansys 11 classic, it is a shell like 2d representation shape; hence narrow and long. I keep getting a warning that "an invalid element type has been selected for element extrusion" I have attempted to use the four shell elastic element types and none will work for extrusion. I have also attempted to mesh the simple 3-d section and i cannot with the shell elastic element options. It should be working with the shell elastic element types, any sugestions as to what I am doing wrong would be much appreciated.
many thanks
Re: Ansys: Creating a simple extrusion from a 2d shell element shape
10/11/2007 9:13 AM
If you try to sweep or extrude an element, the element you need to end up with is of a higher dimensional order - as a rule / in my experience. Put another way, you would surely extrude 1D elements (beams) into 2D elements (Shells) or 2D elements (shells) into 3D elements (solid or 'continuum').
Wish I was here more often.
10/11/2007 9:43 AM
Thank you kindly
Register to Reply 2 comments
