Previous in Forum: No COLA Retirement Plans   Next in Forum: SD Card Not Formatting Due to Invalid Link File
Matlab Code Experts, Logging Holding Registers Real Time Values to Excel
05/18/2019 3:35 AM
Hello dears,
I connected Matlab as master to a slave controller to read holding registers, but I want to write to excel sheet (logging data), after some time read the value then write it to new empty row, with time in other respective column, so I end up with raw data's were I can trend them.
Can any one help me to do the code?
Regards
Re: Matlab code experts, logging holding registers real time values to excel
05/18/2019 3:59 AM
Good Answers: 80
Re: Matlab Code Experts, Logging Holding Registers Real Time Values to Excel
05/19/2019 9:42 AM
You may want to use Matlab's own recording functions to the workspace and then save the file once the simulation is complete.
Use this line to add new test results to your previously defined array in the workspace:
Case_array = cat(1, Case_array, Test_Result); %Tests results from the simulation with conditions
Then save the file to disk:
save('Case_array_File.mat','Case_array');
Later, you can import the file to excel if you need to.
05/26/2019 5:37 AM
Thanks,
Register to Reply 3 comments
Fardan (1); marcot (1); SolarEagle (1)
