Previous in Forum: Weep Holes in Gravity Retaining Walls   Next in Forum: Where Can I Customize the Battery?
9 comments
Trigger for a CMOS Flip Flop
05/20/2019 4:08 PM
I need a simple flip flop triggered by a manual pushbutton. My system runs on 14v, so I used a CMOS CD40175...but that needs a really fast trigger rise/fall. What can I put between the button and the CMOS to do this? Or is there another IC that can tolerate a slow trigger and work at 14v?
Pathfinder Tags: CMOS flip flop
Re: Trigger for a CMOS Flip Flop
05/20/2019 4:21 PM
You don't need a fast rise time. What you need is a clean, debounced signal. I would change the N.O. push button with a N.O./N.C. push button (a.k.a. form C contacts) and send the two signals to the input of a S/R latch that will then drive your single asynchronous counter.
05/20/2019 4:44 PM
Can't change the button (it drives other stuff too), and the cd40175 had a max clock rise/fall of 15 microseconds. Now maybe I could use a 4093 Schmitt trigger for debounce and to give a fast clock to the 40175.
05/20/2019 6:23 PM
05/20/2019 6:41 PM
05/20/2019 10:54 PM
A Schmidt trigger, it has hysteresis, is the classic debounce method​.
https://pubweb.eng.utah.edu/~cs5780/debouncing.pdf​_
05/21/2019 8:43 AM
Why do you think the manual push button will have a slower rise time than 15 microseconds?
05/21/2019 12:24 PM
I tried just the button as the clock and the flip flop went nuts with the bouncing. Then tried a typical RC debounce circuit, but the flip flop can't take the slow rise/fall of that approach. So will now try debounce plus Schmitt as Rixter and rwilliams suggested. That link by rwilliams is very interesting.
05/22/2019 4:49 AM
Schmitt trigger is more or less the go-to standard to de bounce and clean up a noisy signal.Been in use since at least the 1970's. I think it will solve your problem.
05/24/2019 6:08 PM
You should use a RC lowpass followed by a schmitt trigger. The lowpass must debounce your pushbutton bounce to a lower level as the hysteresis difference. The bounce time of a pushbutton may be very long, in worst case the whole pushing time which is user dependent.
Register to Reply 9 comments
HiTekRedNek (1); Randall (1); redfred (1); Rixter (2); rwilliams (1); SSCpal (2); Ulf (1)
