Previous in Forum: Roof Mist Cooling System Design   Next in Forum: Road Trip, Anyone?
Closed Circuit / Hybrid Cooling Tower
06/10/2019 1:38 PM
I intend to design a closed circuit / hybrid cooling tower. Can any one guide me regarding the heat transfer calculations of the heat exchange bundle?
Thanks
Re: Closed Circuit / Hybrid Cooling Tower
06/10/2019 1:47 PM
06/10/2019 2:26 PM
Yes. Perry, "The Chemical Engineer's Handbook", any edition, contains the principles, the charts and the equations.
06/11/2019 7:06 AM
Thank you for the replies.
The references are basically for standard cooling towers. I need designing tips for designing heat exchanger tubes placed within the cooling tower box. The water falling on the tubes is evaporatively and sensibly cooled and with water or fluid inside the tubes is only cooled sensibly.
Good Answers: 38
06/11/2019 11:13 AM
Oho !..... Now we slowly discover what you mean as you slowly make up your mind !!!
Please provide a block diagram or PID of your proposed system for this thread to go forward..... a single sentence description is not enough.
Design tips: look to design a standard TEMA BEM style heat exchanger with forced circulation on both sides. There is no thermal advantage in placing the HX in the Cooling Tower sump
It sounds like what you envision has been incorporated into many power plants under the name "Closed Loop Cooling System".
06/13/2019 1:32 PM
This looks like becoming another of those drip-feed threads, where it isn't until #20 when one discovers exactly what is wanted.
<unsubscribes>
06/13/2019 1:29 PM
#2⇑ still applies.
If in doubt, consult a local Process Engineer.
07/18/2019 2:09 PM
Closed circuit Cooling Tower
In the closed circuit, there is not contact of air with the fluid being cooled. So first there is convective heat transfer from the air to the stainless-steel/or any other materials's pipes being used to carry the fluid to be cooled out. So first of all you will calculate the convective heat transferred to these pipes
Once the connective heat transfer is obtained you will have the temperature of the pipe or cooling transferred to pipe. Using that value now you can use conduction heat transfer formulas to calculate the cooling transferred from pipe to water and the final temperature of the fluid.
for the formulas of convective and conductive heat transfer please refer to this link.
Convective heat transfer
https://www.engineeringtoolbox.com/convective-heat-transfer-d_430.html
Conductive heat transfer
https://www.engineeringtoolbox.com/conductive-heat-transfer-d_428.html
Actuators You Can Depend On
Actuators (1); Anonymous Poster (1); MJCronin (1); PWSlack (3); SolarEagle (1)
