Previous in Forum: Injection Machine Mold Testing   Next in Forum: Nickel-Based Super Alloys
Aluminum Killed and Vacuum Degassed
06/20/2019 2:17 PM
Are these processes ever both done or is it only one or the other? From what I understand of it (through reading different papers and posts), they both accomplish the same thing but the Vacuum Degassed is a newer and more effective method.
Thanks for your assistance!
Re: Aluminum Killed and Vacuum Degassed
06/20/2019 3:29 PM
What process is this relating to?
06/20/2019 3:34 PM
Sorry. This is related to treatment of steel.
06/20/2019 9:07 PM
..."Vacuum degassing is used primarily for removal of hydrogen from steel. The liquid steel is exposed to an evacuated atmosphere for a period of time, typically reducing the hydrogen value to <2 ppm.
Fully killed steel, as stated, is steel that has been deoxidized using either Al or Si. The deoxidant (Al or Si will create oxides that will for the most part float into the slag, but some residual non-metallics will definitely remain in the final product as inclusions and affect the cleanliness. This prevents blowholes/porosity from forming during solidification due to the low solubility of oxygen in solid steel.
Degassing a fully killed steel (a combination of both) will aid in removal of the deoxidation product and can aid in obtaining excellent cleanliness as well as low dissolved gas content."...
https://www.eng-tips.com/viewthread.cfm?qid=194837
06/21/2019 4:35 PM
Vacuum degassing is used to remove hydrogen. Killing is the addition of silicon or aluminum to remove carbon monoxide. Both remove gases that cause bubbles when the steel cools. (I believe degassing is not as effective at removing CO.)
See
Vacuum degassed vs fully killed steel
Register to Reply 4 comments
jack of all trades (1); Rixter (1); scottsuperman (1); SolarEagle (1)
