Previous in Forum: Roll rimming   Next in Forum: Microcontroller Programming: How does the Controller Find the Machine Code?
How do logic gates function?
10/15/2007 12:31 PM
what is the working of logic gates?
Re: How do logic gates function?
10/16/2007 3:33 AM
http://www.google.co.uk/search?sourceid=navclient-menuext&ie=UTF-8&q=logic+gates
2,530,000 in 0.14 sec.
This is the working of search engine.
10/16/2007 10:20 AM
Because each logic gate has a different function (like summing or simply passing a signal through), they are each configured differently when you look at the internal schematic. (also depends on whether you are speaking of CMOS or TTL gates when looking at internal structure).
Additionally, logic gates must "buffer" the inputs...so hooking many of them in parallel does not cause a signal loss. Also, there is a slight time delay every time a signal presented at the gate goes through (propagation delay). Are you after internal structure?
10/21/2007 9:40 PM
once you see lamp lighting or day and night, you will understand how the logic gate works.
Anonymous Poster (1); cnpower (1); electromagnetic1 (1)
