Previous in Forum: 19st.shrif helwan cairo egypt   Next in Forum: How do logic gates function?
Roll rimming
10/14/2007 3:30 AM
Whart is the formula to find out if a 15" roll(inside diameter) with 2" of water at the bottom is rimming? Speeds are up to 400m/min (outside diameter19") it is a metal roll.
Re: Roll rimming
10/15/2007 9:45 AM
Please explain "rimming", I have never heard this word.
Good Answers: 18
Re: Roll rimming
10/15/2007 8:27 PM
Does rimming imply that the water is being carried centrifugally around on the inside of the roll where an open ended 15" diameter roll is immersed to 2" in a water bath? If so, I would suspect that the rimming is indeed occurring, but I would suggest you would need to consult someone at university that deals with transport phenomena calculations.
Re: Roll rimming
10/17/2007 3:41 AM
Thanks guys.
The "rimming" is when the water is spread out in an even layer across the inside of the drum by rotation. The waterlevel is the maximum layer of water in the bottom of the roll when the roll is not moving.
There must be some kind of formula that can get to an approximate speed.
Sorry if my english is not perfect. I'm still learning.
Kasper
Re: Roll rimming
10/17/2007 5:35 AM
There is a mathematical way of doing it though it looks like being quite involved.
The surface of the water will form a paraboloid inside the vessel, unless the bottom of the vessel becomes exposed; one needs to do the calculation to see if the water is touching the rim at this point, for which the height of the vessel, missing from the post, is required.
It might be simpler, given that the speed is variable, to try it and see.
agua_doc (1); Anonymous Poster (1); prbarry (1); PWSlack (1)
