Previous in Forum: Draft Pressure Profile for Natural Draft Furnace   Next in Forum: Pressure Vessel Wall Thickness Formula Using AD 2000 Code
Percent Elongation Calculation as per ASME sec-viii div-1
07/06/2019 3:00 AM
Actually i was design the cylindrical vertical leg supported pressure vessel, the problem comes while cal. percent elongation of conical section. the dimensional features as
ID of large end-334 mm
ID of smaller end-100 mm
nominal thk-8 mm
pv elite result show % elongation 7.33%
my question was which diameter to be considered for Rf radius , so i will get 7.33% value.
thanx.
Good Answers: 137
Re: percent elongation calculation as per asme sec-viii div-1
07/06/2019 9:07 AM
There's something wrong here. If it's steel, strain 7.3% is well above the elastic limit. With E about 200000MPa, stress would be over 14000MPa, vs typical design stress for carbon steel ~ 200MPa.
In a cone, the stress, and hence strain, is highest at the greatest diameter.
07/11/2019 3:07 AM
But, if we consider large diameter ans will become 1.19% by ASME Sec-viii div-1,
(50*tn/Rf)*(1-Rf/Ro) then why pv elite show 7.3% ?
Good Answers: 137
07/11/2019 4:19 AM
I haven't got ASME 8 with me, so can't comment on that formula, but there's still something wrong. Stress and strain are higher at larger dia (for a given pressure and thickness). Typical strain is in order of 0.1% for a steel vessel.
07/11/2019 5:28 AM
Thanx sir.
Register to Reply 4 comments
