Previous in Forum: phenol formaldehyde (bakelite resin)   Next in Forum: 5w vs. 10w oil
10 comments
Composite Laminates, interlaminar & transverse shear effects
10/16/2007 5:14 PM
Guys, I am researching this as a potential PHD topic, the only links I find (and that includes publications) all go back to one source (Pipes & Pagano), there seems to be little empirical work apart from them. Does anyone have any other links they could point me towards?
Many thanks
Roland
Re: COMPOSITE LAMINATES, interlaminar & transverse shear effects
10/17/2007 1:22 AM
You might start looking a Airplane & Space Aerospace sources. A lot has been done i that composite field there.
Re: Composite Laminates, interlaminar & transverse shear effects
10/18/2007 3:21 AM
Composites are also used for building boats. If you have a British Consulates Library close to you, you may find some books throwing light on this topic.
10/18/2007 6:06 AM
Not exactly the topic but maybe you can wind it back from there. Check out the work from Goutianos.
All the best,
Fernando
Going to extremes is no good... Going half-ways is mediocre.
10/18/2007 9:00 AM
Do you have a specific subject in mind for your thesis on laminates? I have worked on robotic systems that needed to cut mass in order to increase mechanical response time. The relative strength of the laminate is only one small part of the picture...cross fiber patterns inside the composite have a tremendous effect on rigidity and interstructural resonance. Here in the disk drive industry, laminates are now used where steel introduces unwanted magnetic coupling effects.
There is a whole new area coming up where laminates will play a role in the solar panel industry...because aluminum substrate needs to go the way of the dodo. Global Spec is a really good place to start.
If you tell me your focus, maybe I could point you to some real research.
APIX Pilot Plant Design Project - Member - New Member
10/18/2007 9:51 AM
Look in the area of Nanotechnology and Nanomaterials. There is lots of work being done in these areas today. You might looks for this at MIT, too, they seems to be in the materials field.
chtank
10/18/2007 10:17 AM
Modern Bows and Crossbows use such technology as well as F1 cars....
Popular Science - Weaponology - Aerospace nut Hobbies - Musician - music enriches the soul United States - Member - Happy to be from the USA Engineering Fields - Acoustical Engineering - Pro Audio Speaker Designer Engineering Fields - Manufacturing Engineering - Aerospace ME Engineering Fields - Aerospace Engineering - Airplane nut from aeromodels to 747's
10/18/2007 10:56 AM
There is a lot of information available at composites world. I would look around there you might find something useful.
Sooter
The early bird gets the worm, but what about the early worm? A.E. Neuman
10/18/2007 12:37 PM
quite a bit of work has been done with regard to radomes for both commercial and military aircraft.
Quartz fiber vs. kevlar vs. glass fiber.
most recent work for E320 adn 787 dreamliner
10/18/2007 2:32 PM
GD (General Dynamics) in Marion VA has a stress guy (only one last time I knew) that does their radome work. If I could remember his name I would tell you but he has a lot of info, knowledge and software that he uses for the radome work. I'll double check when I get home tonight and see what books I have on the subject.
Scooter
11/01/2007 4:36 AM
Hi roland, We all belong to the same family ,composites.I am currently working in the area of thermal buckling. I can tell u something on transverse shear stress.It was started from kirchoff plate theory.In that no transverse shear was considered to finding the dispalcement fields. Lated J.N Reddy formulated first order shear deformation and higher order theory. In these cases u they have considered tranverse shear stress. The is a book called "Mechanics of Laminated Composite Plates and Shells by J.N.Reddy" .This book will give further insight of this transverse shear stress. U can contact me at punith84@rediffmail.com
Andy Germany (1); Anonymous Poster (2); chtank (1); ciplionej (1); dbdwoods (1); electromagnetic1 (1); Humble Ess (1); snewkirk (2)
