Previous in Forum: Flow of Fluid in Piping   Next in Forum: Hydrotreater Test
Effect of Nozzle Loads on Vessel Legs
07/30/2019 10:39 AM
I have been struggling to figure out how to apply nozzle loads to the vessel legs. I use compress (codeware) software to do pressure vessel calculation. It considers the nozzle loads as localized stresses and are not used to analyze the legs. Need help on this topic.
Thanks
RDK
Pathfinder Tags: nozzle loads Vessel Legs
Re: Effect of nozzle loads on vessel legs
07/30/2019 12:52 PM
You need to look under piping restraints and mounting, this I think will determine the additional loading....
https://www.researchgate.net/publication/320637053_Nozzle_Load_Considerations_and_Misconceptions_Introduced_by_Piping_Support_Friction
Good Answers: 137
Re: Effect of Nozzle Loads on Vessel Legs
08/01/2019 7:23 AM
If you know the loads applied by the pipework on to the nozzle - force parallel to the nozzle flange and angle from vertical, force along nozzle axis, bending moment and torsion - it shouldn't be too hard to estimate the additional load applied to the vessel legs. In most cases the additional load is likely to be small compared with the load from vessel and contents.
Also vessel suppliers sometimes state nozzles can accept vertical loads only, no horizontal loads or moments. Might be worth checking that.
08/01/2019 8:19 AM
Thank you, for your response!
I have applied the nozzle loads globally (as vertical and lateral forces) in compress to see the effect on legs.
Register to Reply 3 comments
Codemaster (1); RDK (1); SolarEagle (1)
