Previous in Forum: Innovative Applications for Multimeter   Next in Forum: Use Of On Load Tap Changers
servo motor
10/17/2007 7:14 AM
Can you make me understand by animation notes of servo motor or any link for same...?? If get that will simple to understand for me . Does anyone know where I can find documents about this topic and if so, pls give link available?
Re: servo motor
10/17/2007 7:31 AM
why not search "google.com' for result?
too much motor. even in this globaspec.com you can find a lot.
servo motor works as universal motor. but it has higher resistance and small iteria.
Re: servo motor
10/17/2007 8:41 AM
But unable to find some animated doc. in google or globalspec, if you pls send me link.please
Re: servo motor
10/18/2007 9:13 PM
pay attation to. you will find at last, I think
I dont know the exactly address, but I can tell you the motor has the same princiople as ordinary motor you see in the life.
besides, the servo motor hsa many kinds of structure, such as , ac, dc, permanent magnet pole, power etc. a great deal of.
which one will you use? and where will use it to? what amplifier do you have now? etc. all is important problem.
Re: servo motor
10/17/2007 8:48 AM
Check the thread 'lathe mods', It has links to some very good sites!
Good Answers: 61
Re: servo motor
10/17/2007 10:30 AM
Re: servo motor
10/18/2007 2:59 AM
Dear pwr2thepeople,
I visit the wb site curiously, I find the motor is only selfsynronous motor which have to use in 2 or more together in order that get sync work. one is transmitter and others are reciveer.
strictly speak, servomator is another concept describe above thread. it start fast, and can run nearly zero speed.
Register to Reply 6 comments
anilgchavan (1); cnpower (3); Mr. Truman Brain (1); pwr2thepeople (1)
You might be interested in: Motor Controllers, Servo Valves, Servo Drives
