Previous in Forum: Fuel consumption calculations   Next in Forum: FLAME PHOTEMETER
Binder for cork
10/17/2007 7:39 AM
We have three to five mm cork granule from which we want to make sheet by binding the cork granules together.(Not by latex or natural rubber) some other adhesive or binder (synthetic or natural). Please advice suitable process for above.
Naresh Tagra
email tag_bros@yahoo.com
Re: Binder for cork
10/18/2007 2:30 AM
Have you tried urea formaldehyde?
This is being used to make sheets from wood chips, it should work with cork as well.
Johan.
Popular Science - Weaponology - Cardio-7
Re: Binder for cork
10/18/2007 12:10 PM
In the past, Unisoles and sheets of cork were made by mixing the cork granules with an aromatic moisture curing polyurethane, typically a polyether blend of diols and triols. The mix was then spread into a heated mold and cured, either by added moisture, added gylcerine or similar. One can vary the density, flexability and physical properties of the sheet, or Unisole, by varying the polymer, blend ratio, cure pressure (density) and so on. Millions of Unisole units have been made in the last 30 - 40 years. The polyurethane is typically a low cost commodity polyurethane.
