Previous in Forum: Effect of brazed joint quality on contact buring/welding   Next in Forum: Turning Finish
9 comments
How to Check for Voids in Brazed Joint Quality?
10/18/2007 12:05 AM
I want to check the presence of voids in a brazed joint made between two copper sheets (surface to surface lapping). What is the best method/instrument for doing so?
Good Answers: 58
Re: How to Check for Voids in Brazed Joint Quality?
10/18/2007 11:01 PM
Ultrasonic or x-ray.
10/18/2007 11:42 PM
Agreed!
Another possibility, depending on what equipment you have available, is Thermal Imaging (Heat one side and take an IR picture of the other side)
Engineering Fields - Mechanical Engineering - By Degree Engineering Fields - Manufacturing Engineering - By Profession Popular Science - Weaponology - By Interest United States - Member - Member Since My Inception
10/19/2007 9:22 AM
Ditto.
Light travels faster than sound. That's why some people appear bright until you hear them speak.
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
10/19/2007 4:42 AM
Hi, the best solution is to scan ultrasonically from any side of the two sheets with straight beam. If there is metal continuity, the echo will correspond to the sum of the thickness of both sheets. If some misbonding is present, an echo should appear at a distance equal to the thickness of the sheet from whose side you are scanning (or maybe to that tickness plus the thickness of filler metal)
United States - Member - New Member Engineering Fields - Electrical Engineering - New Member
10/19/2007 8:05 AM
We have always used UT
“There's a sucker born every minute, and I happen to be one of them”
Fans of Old Computers - Vector 1 - New Member
10/19/2007 3:02 PM
A peel test can be used if you have a sample of the joint.
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover." Mark Twain
Good Answers: 25
10/20/2007 6:46 AM
Yes, but peel test is destructive and can be used only as "qualification test" to set the process parameters, Which is obviously recommended, but not feasible for quality control of all welds.
10/24/2007 1:19 PM
thre is a simple test which is available in the market is die penitration test.
there are three solution one is cleaner second one is penetrator, third one is developer.
for this you have to grind the joint and spray the above spray and you will come to know the deffect.
Good Answers: 25
10/25/2007 10:26 AM
Thank you for you cooperation, but dye penetrant is a NDE technique which allows to detect only surface open defects and in a brazed joint you could only check if the visible part of the weld (obviously minimum) has continuity. You can't detect "voids"
Register to Reply 9 comments
All About M.E. (1); Anonymous Poster (1); BRANSON (1); dkwarner (1); Kwetz (3); T Man (1); welderman (1)
You might be interested in: Check Valves, Caulk, Grout and Joint Compounds, Pliers
